Pir8radio
Sep 15, 2017Tutor
WAC510 Android Devices Disconnecting constantly
You recently fixed my issue with android devices not being able to connect to the wac510, however they dont seem to stay connected. See below log, let me know what else you need. I've tried disable...
- Oct 21, 2017
Raghu
I received a beta firmware from your colleagues and I must say that my issues have been resolved. Well done to you and your colleagues and NETGEAR. Hopefully this also resolves issues other users have had.
RaghuHR
Sep 17, 2017NETGEAR Expert
Hi James,
Welcome come back. Is this 00-9E-C8-B5-48-A7 mac address of your Android TV? Do you have any other wireless clients having the same issue? Please download the detailed logs and share the packet capture as well. We will take a look at this issue.
Thanks
Raghu
- RaghuHRSep 19, 2017NETGEAR Expert
Hi James,
Just wanted to check with you. Is there any further update on this?
Thanks
Raghu
- RaghuHRSep 20, 2017NETGEAR Expert
Hi James,
We have released new firmware (1.5.3.6) y'day. Could you please try out that and see if you see the same issue?
https://kb.netgear.com/000048461/WAC505-WAC510-Firmware-Version-1-5-3-6
Thanks
Raghu
- RaghuHROct 02, 2017NETGEAR Expert
Hi James,
do you have any further feedback on your issue?
thanks
Raghu
- Feb 04, 2019Retired_Member
