Pir8radio
Sep 15, 2017Tutor
WAC510 Android Devices Disconnecting constantly
You recently fixed my issue with android devices not being able to connect to the wac510, however they dont seem to stay connected. See below log, let me know what else you need. I've tried disable...
- Oct 21, 2017
Raghu
I received a beta firmware from your colleagues and I must say that my issues have been resolved. Well done to you and your colleagues and NETGEAR. Hopefully this also resolves issues other users have had.
RaghuHR
Sep 19, 2017NETGEAR Expert
Hi James,
Just wanted to check with you. Is there any further update on this?
Thanks
Raghu
RaghuHR
Sep 20, 2017NETGEAR Expert
Hi James,
We have released new firmware (1.5.3.6) y'day. Could you please try out that and see if you see the same issue?
https://kb.netgear.com/000048461/WAC505-WAC510-Firmware-Version-1-5-3-6
Thanks
Raghu
- RaghuHROct 02, 2017NETGEAR Expert
Hi James,
do you have any further feedback on your issue?
thanks
Raghu
- cifellcOct 05, 2017Tutor
I have the same exact issue with one of my devices, it was connecting properly but now
i am getting NETGEAR WAC510
IEEE 802.11: Station disassociated due to reason code 8. I have tried everything as well.Yes I am on the latest firmware, all to no avail. In order to use the device I need to crank up my old access point. So I know its not an issue with the device. Netgear.. Help- RaghuHROct 05, 2017NETGEAR Expert
Hi Carmen,
Can you please share the model & version of your Android device?
Please start a packet capture (refer attached screen for packet capture) before connecting your Android device and capture till you see the issue. You can save and send it us for debugging.
Thanks
Raghu
- Feb 04, 2019Retired_Member
