Pir8radio
Sep 16, 2017Tutor
WAC510 Android Devices Disconnecting constantly
You recently fixed my issue with android devices not being able to connect to the wac510, however they dont seem to stay connected. See below log, let me know what else you need. I've tried disable...
- Oct 21, 2017
Raghu
I received a beta firmware from your colleagues and I must say that my issues have been resolved. Well done to you and your colleagues and NETGEAR. Hopefully this also resolves issues other users have had.
RaghuHR
Oct 08, 2017NETGEAR Expert
Thanks. This is much useful info. We will check and come back to you. Do you mind you can be on this firmware till we root cause this?
Regards
Raghu
cifellc
Oct 12, 2017Tutor
Raghu,
I was unable to attach the file in the response to your email.
I am attaching zip file with the pcap files here.
- Feb 05, 2019Retired_Member
