BoT
Jul 15, 2017Aspirant
WAC510 Frequent power cycling
I bought a 3 pack of WAC510's. I installed them and am happy with their performance. Up until recently everything worked as expected but i believe since the firmware update 1.2.5.12 my AP's started r...
- Jul 21, 2017
At Raghu's suggestion I turned RRM off on both devices and that appears to have done the trick. Both of WAPs have been up for 3+ days with no restarts.
Sounds like there might be a bug in RRM that will get addressed with the next update.
Disabling this hasn't appeared to significantly impact our network performance, although andecodally one android client user is complaining that his device is not acquiring/holding connections as well. Could easily be something else going on there.
Dsmalley
Jul 17, 2017Tutor
Also - I installed kiwi, enabled syslog, and attached that log data as well. It looks like one of the devices restarted 3 times overnight - very low / no activity.
RaghuHR
Jul 17, 2017NETGEAR Expert
Hi Doug
Thanks for sharing much needed info. We will analyze and come back to you if we have any further questions.
Best,
Raghu
- mycroft_holmesJul 17, 2017Aspirant
Same thing here.
It's particularly annoying because a lot of the equipment that we have will not recoonect automatically.
- RaghuHRJul 17, 2017NETGEAR Expert
Are you seeing the WAC510 restart and after restart wireless clients do not reconnect to WAC510 . I'm just trying to understand your issue in more detail. Nice if you can add more details
Thanks
Raghu
