BoT
Jul 15, 2017Aspirant
WAC510 Frequent power cycling
I bought a 3 pack of WAC510's. I installed them and am happy with their performance. Up until recently everything worked as expected but i believe since the firmware update 1.2.5.12 my AP's started r...
- Jul 21, 2017
At Raghu's suggestion I turned RRM off on both devices and that appears to have done the trick. Both of WAPs have been up for 3+ days with no restarts.
Sounds like there might be a bug in RRM that will get addressed with the next update.
Disabling this hasn't appeared to significantly impact our network performance, although andecodally one android client user is complaining that his device is not acquiring/holding connections as well. Could easily be something else going on there.
Dsmalley
Jul 21, 2017Tutor
