woffy's avatar
woffy
WAC720 successor
Hi I have a customer with severalWAC720 in an ensemble/roaming arrangement
Please advise a suitable current model to add to the mix or is it not possible
Support chat was not possible as there were no agent available
Thanks Des
  • Hello Des woffy​
    No direct replacement, no more ensemble APs available I'm afraid. Times have changed towards cloud management, WPA3, ... Huge wireless bandwidth up to 12..20 Gb/s, and WiFi 7 are standard today.
    Second hand market for WAC720/730 probably?
    -Kurt.
  • Ok ended up with a s/h WAC720
    it will not join ensemble rather it starts a new one and commandeers management IP
    Also it seems it came from US and only has US/Canada as an option for country/region
    I have updated firmware on all to V3.9.1.13 still no joy
    is there a workaround for country/region or should I look elsewhere for WAPs
    • schumaku's avatar
      schumaku
      FCC and other strict regulation bodies don't allow free regulatory changes.
      There is no official supported way to make this happen.
      • woffy's avatar
        woffy
        Thanks for info
        only for units sold in US it seems
        it would be nice to bring it in line with those sold in the rest of the world where we can select our country/region
        is there an unofficial way before I scrap the unit?
  • schumaku's avatar
    schumaku
    Hello Des woffy​
    -Kurt.
    • woffy's avatar
      woffy
      Thanks for info appreciate it
      not so much looking to manage new one that way more for ability for users to seamlessly roam from WAC720 connection to what ever the new one is with same SSID and vice versa
      if not either total replacement or secondhand WAV720 will have to do
ProSupport for Business
