Geoff-NZ
Apr 29, 2022Apprentice
WAX610
I've got a WAX610 with firmware version 9.6.2.6. I have multiple SSID's configured and with one of these SSID's I have enabled a WiFi activity schedule. When the WiFi activity schedule triggers on or...
- Aug 23, 2022
I am adding this information in case anyone else experiences this issue and wants a possible solution.
The root cause of my issue was that the beacon frequency changes when transitioning to more than 4 active SSIDs or transitioning to less than 5 active SSIDs as this causes all SSIDs to restart, hence the disconnection I was experiencing. As I had one of 5 SSIDs on a schedule, I was getting a disconnection whenever the scheduled time to activate the 5th SSID was enabled or disabled for this reason.
My solution was to add a 6th SSID (have left it hidden at the moment) so that when my SSID on a schedule is enabled or disabled, the total number of active SSIDs never goes below 4, which seems to have resolved my issue.
Thank you DaneA for following up on this issue with Netgear support.
DaneA
Jun 30, 2022NETGEAR Employee Retired
Thank you for the feedback.
With regards to this, I suggest you to open a support ticket with the NETGEAR Support Team here at anytime for further investigation. It would be best that you download the detailed AP logs when the issue occurs then attach it to your support ticket.
DaneA
NETGEAR Community Team
Geoff-NZ
Jun 30, 2022Apprentice
DaneA how do I create a support ticket though?
Apparently, I'm only allowed to create a support ticket within 3 months of purchase. Do I need to purchase another AP or a support contract just so I can create a support ticket about a bug in the firmware? That is why I ended up raising this issue in the community.
I understand why many issues can be resolved in a community forum, however, I don't understand why consumers are only able to report bugs within 3 months of purchase.
- Geoff-NZAug 23, 2022Apprentice
