Funked
Apr 19, 2016Follower
WMS5316 Airprint
I work for a school that has a WMS5316 controller with a few WNDAP350 APs. They've recently got some iPads, so we got Konica Minolta to upgrade the firmware on the printers to enable Airprint. Th...
- May 09, 2016
I found the answer to my own question. There was an undocumented and unconfigured (not even on the same subnet, so not showing up on DHCP or network scans) Netgear switch being used to give POE to the access points.
I had a poke around in the settings, and turning off "IGMP Snooping" instantly cured all Airprint issues.
Funked2
May 09, 2016Initiate
JohnRo
May 12, 2016NETGEAR Employee Retired
Hello Funked2,
Thank you for the update. I'll mark this as an "Accepted Solution" and will serve as a workaround for AirPrint issues as of the moment.
Thanks,
