jsroman's avatar
jsroman
Insight Toplogy not visible in abstract view.
Tree view and ssid view work as intended under Toplogy Views on Insight Portal but when switching to Abstact view nothing is visible. Any suggestion on how to correct. A wac540 and a wax610 are APs attached at location.
Thanks in advance.
  • Retired_Member's avatar
    Retired_Member
    Jun 14, 2021
    Hi,
    We have released newer version of IM6.2.
    Could you please try viewing "Abstract View" of the topology now?
    Please let us know.
    Thanks,
    Sudheer
    Retired_Member
    Hi,
    We have fixed this issue in IM6.1MR version.
    Could you please provide Insight credentials to debug further?
    Thanks,
    Sudheer
      Retired_Member
      Hi,
      You can give technical support access or provide your credentials by sending email: [email protected].
      Thanks,
      Sudheer
      • jsroman's avatar
        jsroman
        I granted tech support access thru insight , now what do i have to do?
    • jsroman's avatar
      jsroman
      Are you seriously asking for my Insight user name and password on public forum?
      Retired_Member wrote:
      Hi,
      Thanks,
      Sudheer
ProSupport for Business
