Techdeskxy
Feb 08, 2024Aspirant
After doing the firmware update via the Insight app my Orbi pro stopped working
After doing the firmware update via the Insight app my Orbi pro stopped working. I have factory reset a couple of times but, still getting the same problem. The white light blinks for a while then it stays on. I can connect to the default WiFi but, unable to reach the router configuration page.
have you checked to see if the IP address for the router changed? I've see a firmware update cause a reset (or you reset) and it defaults to a different iP address if there's a conflict
- TechdeskxyAspirantAfter the reset I connected directly to the modem. And the modem is set with DHCP mode so the IP changes for the Orbi. Before I had these issues, I had the Orbi set on a static IP but I have since removed that.
- plemansGuru - Experienced UserIt's the orbi in ap mode if the gateway is handling dhcp
- TechdeskxyAspirantI have not been able to reach the orbilogin.com or reach 192.168.1.1. In the modem it is showing another IP address but, I also have factory reset the Orbi. At the moment I am at a loss.
I had the same issue, where I could not reach the Orbi config page on orbilogin.com on a PC. I finally tried with Firefox and the default SSID and password after the factory reset. Disabling all the security features in Firefox, got prompted to enter admin password. I was able to enter to do the config, even without the Orbi connected to the internet.
- DavidGoNETGEAR Expert
We have shared a patch firmware for this issue which has so far been successful. We are working on an official release which will include this fix, will share the ETA once I know more.
If anyone else runs into the issue and wishes to try the patch, please send me a DM.
Thanks
DavidGo
