Nickthequick's avatar
Nickthequick
Initiate
Jul 14, 2026
AX600 missing Port Forwarding setting
I have an AX600 in router mode that has been running for multiple years with the same configuration and I had a port forward rule configured that was working on the initial setup. I am trying to edit the Port Forward rule but I am not seeing the setting/option anywhere in the management portal. I see everything that I normally see but am missing any Security and Firewall settings. What am I missing?
  • SXR80 is the model, I was mistaken. I was trying to find the settings remotely since I wasn't on the LAN at the time via the app and via the online management portal. Still don't see it anywhere. I did find it via the LAN mgmt portal once I was able to be on site
  • FURRYe38's avatar
    What model product is this?
    Orbi Pro SXK###?
    You logging into the routers local web page?
    What browser are you using?
    • schumaku's avatar
      schumaku
      SXK### are the kit SKU.
      The router (where the port forwarding is available) are SXR###
      The SXS### are the satellites without port forwarding controls.
      Correct, double check you are logged-in on the primary router.
      • FURRYe38's avatar
        Ya I know this. Thanks.
        Asking the OP about this...
ProSupport for Business
