DeadlyHifi
Oct 18, 2021Guide
SXR80 - Network drops on Voice/Video (zoom etc)
Hi all,
I'm hoping you can help as I have a odd isue that is driving me mad - I don't even know for sure it's the router.
I've been having periodic freezes on my zoom calls, Teams calls etc. could be every 60 seconds or every few minutes.
I've been monitoring throuput traffc and I'm seeing drop off on recieving traffic.
I also tested on my mobile connected to the network and see similar.
On my pc this is ethernet connected.
sorry this is vague - networks aren't my strongest area. Any ideas please?
thanks
- Hi all. I have solved the problem for me. I had the Orbi originally doing the pppoe - I've since switched this off and put it on to a router modem provided by the ISP. Since I've done that and the Orbi is no longer performing the authentication the problem is solved. I've no idea on why or how but that's the experience I've seen.
Thanks all.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Answers in line. Thanks for coming back.
V3.2.6.100 - recently had to roll back because the latest had satelite drops.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Fritzbox Modem. I'll check the model and come back.
What is the size of your home? Sq Ft? - not sure - but this is happening wired direct to the router as well as wireless.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡they are around 8 meteres apart, but through thick walls so any further and the signal degrades.
I have channel 6 enabled but as above - seeing this on wired. Though I do also see the issue wirelessly
Any Wifi Neighbors near by? If so, how many?Plenty but I checked wifi congestion and channel 6 was pretty clear. Along with 44
- quagmire1Luminary
So this happens even if your PC is connected to the router via Ethernet, and the router is connected to the cable modem via Ethernet? If so, I doubt the Orbi is your problem. Are you using a VPN to connect to Teams and Zoom?
Just as a point of reference, my wife works from home and is probably spending 50 hours/week on either Zoom or Teams. In the rare event there is an issue, it's usually traceable either to Microsoft or the cisco VPN her work requires her to use. It's never been the SXK80. (And before the SXK80, we had an Orbi RBK22. That was also trouble-free.)
- BruceGuoNETGEAR Expert
Hi All
1. Are you able to show ping results during the period to see if any break or latency increase?
2. If you see someting wrong in ping, if you have another AP, can you narrow down it is Orbi Pro issue by trying with other AP to see if it only happens when you clients connect to Orbi Pro
- I'm not massively technical but I have been watching the task manager throughput and what I see is a drop to zero on the receive data. Then a quick spike and catch up. Like the door was shut for a second.
- RaghuHRNETGEAR Expert
Hi DeadlyHifi portishead quagmire1
Do you know the ping delay when you hit the issue? Could you please share the debug log at the time of the issue? You can run the ping to internet and see if there is any signficant delay when you see the drops. PM me the logs to downloads.
Thanks,
Raghu.
