smoddelm
Mar 31, 2023Tutor
Obri RBK850 - Armor "Exception from Onecloud"
This morning when I logged onto the Orbi android app, I immediately noticed in the security block where the status of Armor is indicated that it said in red letters "Protect with Armor Now." I have an active Armor subscription (I have verified the end date), so I clicked on the Security block and was greeted with "Exception from OneCloud." I've Googled and searched the forums and get zero hits. Can anyone explain what might be going on?
- BobbersAspirant
I have the same error message when trying to access Parental Controls and Device Manager. Was here to ask the exact same question!
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.I would submit a bug report:
- ashred13Aspirant
I rebooted the router multiple times from the Orbi app itself and it did nothing.
I was getting to the point where I was going to try a Factory reset of the Orbi router because a help page indicates that you will have to manually set up the Armor and Parental Controls again. So I thought maybe turning off the security protections might get it to work again. I turn off my wifi at night due to a sneaky child and I can't turn it back on because of this error message.
Turn on computers and rest of network.Please hold off on doing any Factory Reset for now.
- LongWuAspirantI have the same issue
- Chuck-IVGuide
Getting the same error. The security portion says it's not activated and when trying to go into it, it gives the "Exception from OneCloud"
I'm guessing either a OneCloud issue directly or the new app update(at least for iOS, got one yesterday) screwed up the linking,
Yes, noticed this as well.
I've passed this onto NG for review.
Please be patient.
- smoddelmTutorI tried the modem / router reboot sequence that was suggested and it didn't fix the problem. Seeing that others are having the same issue and have reported it, I will wait for now.
- Hannah123InitiateMine is same thing
