SenperFi's avatar
SenperFi
Nighthawk app log in
Good morning, I have spent about 3-4 hours with support attempting to log into the Nighthawk app. It is a new modem router cax80
When I log in with admin and my password (changed using my router login), it will attempt to get to the dash board but then time out
I have
rebooted numerous times
reset to factory settings
I am attempting to log in with my apple device and we have tried it on my wife's cell phone and same time out  issues
Regards
Pete
  • plemans's avatar
    Are you able to log in through the browser?
    • SenperFi's avatar
      SenperFi
      Yes I can log into my modem/router via the browser but not the app on the iphone (s)
      • plemans's avatar
        did you try disabling random mac/ip address and Icloud relay on the iPhone
    • SenperFi's avatar
      SenperFi
      I dont have the specific number of the firmware but when I set up the CAX80 on 2/10 part of the process was updating the firmware.  In addition, while trouble shooting with the netgear folks, it was confirmed that I had the latest firmware running
      After typing this i will login into myrouter and check
    • SenperFi's avatar
      SenperFi
      Good afternoon, I have tried numerous suggestions and still have not been able to log into the app.  The last suggestion was to do a factory reset, I had done that twice with netgear support and that did not work.  I did my set up for the cax80 via wireless and someone suggested going via ethernet cable to a PC??
      My gripe is , if you put an app out and in the instructions it can be set up wirelessly (new word) then why does it not work
      I have spent over 3 hours with netgear folks and the answer to me was the techs are working on an update for the app
      Regards
      Pete
      • SenperFi's avatar
        SenperFi
        Well then. On 2/26 I attempted to log into the app (as I had been doing daily. So I was able to log into the app. In addition I have been able to log in everyday since. Additionally I have been able to log in from “anywhere “.
        Not sure if I can pinpoint the change, I appreciate all the suggestions. Looks like a bit of Fox Mike to me
        Pete
