gworley's avatar
gworley
Parental Controls not working properly
I manage 2 sites -- home and a homeless shelter.  Both sites I have installed Netgear routers.  At the homeless shelter I have a WNR2000v3 installed and it supports Parental Control.  At home I have WNDR4300 and it supports parental controls. The issue I am having is very simple on my personal laptop when I try to go to parental controls I get an error message:
Yet on another PC on the same network I am able to configure parental controls.  At home I have the same error message yet from 5 other devices (2 PC's and 3 Android devices) I am able to confiigure the Parental Controls.  At the homeless shelter every device that we have I was able to run Netgear Genie to get to the Parental Controls settings.
Laptop information is HP Pavilion Notebook 17-g034cy N5Y50UA#ABA running Windows 10 build 10240.   One other piece of information -- websites aren't being blocked from the laptop   I configured the router at the homeless shelter to block adult sites and on all tested devices accept this laptop http://www.playboy.com was blocked.  This laptop was able to display it without any blockage.
Here is ipconfig /all if that helps:
[C:\Program Files\JPSoft\TCMD18_x64]ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : george-laptop-2
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek PCIe FE Family
                                       Controller
   Physical Address. . . . . . . . . : 3C-A8-2A-B1-3C-CB
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 13:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct
                                       Virtual Adapter #3
   Physical Address. . . . . . . . . : C6-8E-8F-CF-40-C1
Wireless LAN adapter Local Area Connection* 14:
                                       Virtual Adapter #4
   Physical Address. . . . . . . . . : C4-8E-8F-CF-40-C1
Wireless LAN adapter Wi-Fi 2:
   Description . . . . . . . . . . . : Realtek RTL8188EE 802.11 bgn
                                       Wi-Fi Adapter
   Link-local IPv6 Address . . . . . :
                            fe80::3d2d:a843:47f3:9837%23(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.23(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Saturday, September 19, 2015
                                       11:58:52 PM
   Lease Expires . . . . . . . . . . : Monday, September 21, 2015                                          12:51:24 AM
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 113544847
   DHCPv6 Client DUID. . . . . . . . :
                          00-01-00-01-1D-21-26-C0-3C-A8-2A-B1-3C-CB
   DNS Servers . . . . . . . . . . . : 192.168.1.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 12:
   Description . . . . . . . . . . . : Microsoft Teredo Tunneling
                                       Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
   IPv6 Address. . . . . . . . . . . :
                     2001:0:9d38:6ab8:1c9a:e82:3f57:fee8(Preferred)
                              fe80::1c9a:e82:3f57:fee8%9(Preferred)
   Default Gateway . . . . . . . . . : ::
   DHCPv6 IAID . . . . . . . . . . . : 150994944
   NetBIOS over Tcpip. . . . . . . . : Disabled
   Tunnel adapter isatap.{ED89777E-7703-4214-91EC-B8B2A2598D78}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
I am using the lastest version of Netgear Genie version 2.4.12.   Here is the computer profile as generated by Netgear Genie:
Your Computer Details:
Network Interface
20
HardwareAddress: 3C:A8:2A:B1:3C:CB
IP Address: fe80::644e:a40:d5ec:a382%21
Netmask: ffff:ffff:ffff:ffff::
Broadcast:
IP Address: 169.254.163.130
Netmask:
Broadcast:
Description: Realtek PCIe FE Family Controller
9
HardwareAddress: C4:8E:8F:CF:40:C1
IP Address: fe80::3d2d:a843:47f3:9837%23
Broadcast:
IP Address: 192.168.1.23
Netmask: 255.255.255.0
Broadcast: 192.168.1.255
Description: Realtek RTL8188EE 802.11 bgn Wi-Fi Adapter
Operating System
Caption: Windows 8
CSDVersion: No Service Pack Installed
WindowsDirectory: C:\WINDOWS
Note I am running Windows 10 even though it says 8
This very frustrating.
George
MSCE
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi gworley,
    May I know if you are using the Insider Preview build of Windows 10?
    You may try setting a static DNS for your laptop and use the OpenDNS one which are 208.67.222.222 and 208.67.220.220 and see if the Parental Controls work.
    Dexter
    Community Team
    • gworley's avatar
      gworley
      Hi DexterJB,
      Thanks for the reply.
      I am currently using build 1024 of Windows 10.
      I am using the OpenDNS DNS servers on the router but will try them on the laptop.
      Thanks,
      George Worley
      MSCE
    • gworley's avatar
      gworley
      Hi again DexterJB
      I meant to ask, how can I do a clean install of Netgear Genie?
      George
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi gworley,
        You may uninstall and re-install it just the way you would with other programs, through the Control Panel.
        Dexter
        Community Team
  • Purchased a Nighthawk x4s AC2600 yesterday, turned on parental controls, checked it and it literally allows anything and everything through even on the highest setting.
    Netgear has virtually zero customer care, and now I find out that Netgear have known of this harmful failure since at least January 2016 September 2015 and done ZERO about it!  After reading more posts where its contributors blame the user, or the user's software and/or hardware when they must know it is their software: the only word to describe Netgear's behaviour is deceptive.
    I have updated the firmware, double checked the settings and it is seriously disturbing that a so-called major industry player continues to ship products knowing that their advertising is false and mis-leading and further, that customers relying on these promises can inadvertently be exposing their children to major harm.
    Frankly, this is an unconscionable and deliberate failure by Netgear to fix its software and I will be raising this with the authorities and media on Monday morning.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi @cricket16,
      1. What is the firmware version of the router?
      2. What version of NETGEAR Genie do you have installed?
      3. Are all devices affected (wired and wireless)?
      4. What are the DNS values on the device UI?
      5. Have you tried changing the filtering level using other devices (smartphone, tablet, other computer)?
      Dexter
      Community Team
      • mrekimf's avatar
        mrekimf
        Apprentice
        How do you set these DNS values? I see replys to change or set the DNS values but not how? I windows 8.1, and setting parental controls on devices but not working.
        My router firmware is
        V1.0.4.30_1.1.67
        netgear genie version is  2.4.20
        thank you
