RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Thanks
- Netduma_JackNetDuma Partner
Could you paste your config file and your VPN log into this thread and we'll help you get this working. Thanks.
- RaleighEdAspirant
Since posting last night, I was able to get the status to "connected", but checking for leaks shows that my connection still isn't secure.
Do you mean DNS leaks? This is a known issue if so, it will be fixed in the next firmware.
- BonkeydaveAspirant
I have my vpn set up correctly using hidemyass and works great. However I want the vpn not to be used when using Netflix. If I click on add service and then advanced does anyone have any ideas what to add or how to add a custom service with Netflix details please.
thanks dave
- Netduma-FraserNetDuma PartnerHi Dave, I believe you've made a post on the Netduma forum where I have already replied to you. In summary, whatever you want to VPN it may be easier for you to just apply the VPN to that and it would exclude everything else. Also Netflix will likely use the standard internet ports (80 & 443)
Just installed the latest FW and am now using the Hybrid VPN with NordVPN. A few questions;
1. This should be configured with the nearest VPN server for the best connection/latency correct? The games I play will auto connect me to servers based on my VPN connect and not my real connect.
2. So If I use a VPN server outside of my Geo-Filter radius then I will have to reconfigure the radius, based on the location of the VPN server I connect to, right?
3. Hybrid VPN feature is something that I shouldn't use except if I'm experiencing DDoS attacks frequently since the connection increases latency and VPN servers tend to be slow?
4. Lastly, I connect to Xbox Live from behind a business firewall and I noticed thatmy NAT Type is now strict when I use the Hybrid VPN. It says; 'Double NAT detected'. So far it doesn't seem to affect my gaming...Should I put the Xbox on the DMZ to resolve this?
- Netduma-FraserNetDuma Partner1. Yes I'd recommend you select the nearest VPN server to your actual location in order to limit the added latency of connecting to a VPN.
2. Correct, move your Geo-Filter location to the VPN server location.
3. It's up to you when you want to use it but it will increase latency and lower speeds. That's why the Hybrid exists to apply it to specific services/applications e.g. just apply the VPN to Skype on my PC, then allows the rest of the PC to be unimpeded.
4. I would suggest so but it's more likely the VPN itself if blocking the ports necessary for an open NAT.Got it! Thank you for the clarification! Much appreciated!
- LevelUpLiam24Apprentice
Hey all, question for you regarding expressvpn and the xbox via the XR500.
I spoke with expressvpn support because the xbox is the only device experiencing issues since setting up via HybridVPN. The issue is moderate NAT.
ExpressVNP support said "I think the issue is because you're using a two Nats. Please note that when you're using a VPN, you go through our networks which leads to another NAT which makes it moderate or in some cases strict. (Good thing, we don't provide Nat Firewalls) and then another NAT on your router."
Does anyone know an issue to resolve this? I'm sure there are gamers that use VPN services and have an open NAT, I've read of people that use a VPN specifially to achieve open NAT.
Any help is greatly appreciated.- Netduma-FraserNetDuma PartnerI would suggest you ensure the XR500 is in the DMZ of the upstream modem/router or the hub is in modem mode. Put the console in the XR500 DMZ mode and that will help with NAT. Also disable the Geo-Filter fully before boot up. Does that resolve your issue? How are you measuring NAT by the console network settings or the game reading?
- LevelUpLiam24ApprenticeWith a few hours support we still couldn't get this resolved and honestly I think it was due to expressvpn not enabling port forwarding on their end. I decided to check out purevpn especially since it's native with the firmware. However, there isn't any support for the ddos dedicated IP? Is there any plans to implement this? Also you have to purchase the port forwarding addon to ensure open NAT.
Still new to using a VPN for gaming, so I'm open to suggestions if anyone has any.
- chaoticbelieverAspirant
Launch a web browser from a computer or mobile device that is connected to your router’s network.
Enter www.routerlogin.net.
A login window displays.
Enter the router user name and password.
The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive.
The Dashboard displays.- Click Settings > Advanced Settings > VPN Client.
- Select the Enable VPN Client check box.
- Select your VPN provider (eg. Ivacy VPN) from the VPN Server drop-down menu.
- Select the VPN protocol, country, and city that you want to use for your VPN connection.
- Enter the user name and password provided by your VPN service provider.
- Click the Connect button to connect to your VPN service.
- Your VPN service is enabled.
- maallenAspirant
Hi,
I have my HybridVPN setup with NordVPN, everything works as expected however sometimes the connection will fail after a period of time and I'm required to login to the router interface and disable and then re-enable HybridVPN which gets the connection back up & running. Is it possible for the router to do this automatically if an active VPN connection drops out?
- Netduma-FraserNetDuma PartnerNot exactly, you have the option to block traffic if the VPN disconnects so you can then connect to a different server to re-establish the connection. I don’t believe it will do this for you. How long is it before the connection drops? Does it consistently do this and same time frame each time?
- Lm60AspirantHi,
I have it setup and working but my problem is when I turn the vpn on I get double Nat on the Xbox. It’s only when the vpn is on. Not sure what is causing this?
Thanks for your help
Luke.- Netduma-FraserNetDuma PartnerHi Luke, that's down to the VPN, they may block ports that are required for an Open NAT. May be worth looking for a gaming VPN or asking them if they can unblock ports on servers your account uses.
Thanks for sharing this information @bacevedo.
- BreebzAspirant
I have a subscription to HideMyAss vpn and using that for my Hybrid VPN connection. The only connections I have to Hybrid VPN is 2 PS4's. When the VPN is on and says connected I can not access any games on the PS4. When I turn the VPN off I have no issue connecting to games. Please help !!!
- Netduma-FraserNetDuma PartnerDoes it occur on all games you're playing? Are you using the Geo-Filter at the same time?
