RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Thanks
- rbroz73Tutor
Has anyone got IPVanish VPN to work with the XR500?
- Netduma-FraserNetDuma PartnerAre you using the IPVanish OpenVPN configuration files?
- dglsmcd_USMCLuminary
The configuration files for ipvanish can be found here:
https://www.ipvanish.com/software/configs/?_ga=2.61144676.939145539.1599761612-1299560907.1599761612
Download configs.zip to download all the available config files or pick the one that is best (closest) to your physical location:
https://www.ipvanish.com/software/configs/configs.zip
- Cryp1icAspirant
Hello, I need big help trying to figure out setting up my vpn with the xr500 I spent 5 hours last night trying to get it to work and I’m completely lost. I am not a networking guy at all. I tried my best but you all got me confused as hell with this download the config file and all that. Lol. I need help. I am going to provide a screenshot of the instructions I think I’m supposed to use and my current situation.
- Netduma-FraserNetDuma PartnerCryp1ic you're using the VPN service feature rather than the Hybrid VPN feature. What is your reason for trying to use a VPN? Then I can point you in the right direction.
- JoeFIApprentice
Hi,
I'm trying to connect a hidemyass VPN and in your instructions it says to toggle disable then add sign in details for hidemyass, then says to enable before connecting. That option isn't possible for me, can you help please?
Joe
- Netduma-FraserNetDuma PartnerYou're using the VPN service which is the wrong feature. Click Hybrid VPN on the left hand menu of the interface - not in Settings, then you can continue with the instructions.
- JoeFIApprenticeHi, yes that is what I was doing. I've sorted it now.
- qloftyAspirant
Do you know if this feature will be coming to the XR1000. Only VPN option i see is under the advanced settings and that would apply to the whole network.
I would like to only apply it to specific devices.
The VPN in Settings is a VPN service so you can connect to the router from somewhere else. Don't have an estimate for Hybrid VPN, that's up to NG.
