Zelcor's avatar
Zelcor
XR500 Reboots randomly
So I bought a new XR500 from Best Buy last month and there's been a strange consistent problem.
It randomly reboots and then the internet doesn't work.
If I reboot the router again the internet light still doesn't go back on and the connection is still broken.
If I reseat the network cable the internet is back.
So it goes like this.
Router reboots > all connection lights return online > internet light stays red > reseat the network cable.
And I'm back in business until it decides to reboot again.
I read some other posts and there maybe some kind of beta firmware I can download to get this resolved? Can anyone help me out?
    • Zelcor's avatar
      Zelcor
      Netduma_Alex wrote:
      This may seem obvious but have you tried a different cable?
      Yes I have, swapped out the cable that it came with in the box and changed it to the one I had on my old router.
  • FURRYe38's avatar
    • Zelcor's avatar
      Zelcor
      2.3.2.40
      Arris SURFboard SB6183
      I'm pretty sure it's set to auto. I'll give changing the channels a try.
      Yes, quite a lot. But why would nearby wifi's force reboot my router and break the internet connection?
      • FURRYe38's avatar
        When the wifi is set to auto, the router will try to find a good clear channel to use, when the router encounters a noise channel, its trying to find a better channel. Since you say you have many other wifi neighbors near by, you maybe in a wifi congested area. This would be problematic.
  • Unfortunately, I now have the same problem. I bought this router about a month or so ago and haven’t had any issues until two days ago. Magically, the router will reboot itself and not recognize the LAN/Ethernet/internet in port (light just stays red, even while the others are white again). I came across your thread by searching for the issue.
    I tried the firmware update that was linked and it didn’t help. Additionally, the router logs magically get wiped after it decides to reboot, so I can’t even use the logs to figure out what’s causing the reboot.
    I’m extremely disappointed (and honestly irate). I wasted $300 for a router that obviously doesn’t work.
    • FURRYe38's avatar
      What devices do you have connected to the XR router?
      Downgrade to v32 FW version please...Factory reset and then setup from scratch to see if the problem continues.
      • biancaj's avatar
        biancaj
        Guide
        Firmware - 2.3.2.40-c424a, which was linked here as something that might resolve the problem.
        ISP - Comcast
        Modem - Motorola Arris SB6190
        WiFi neighbors - yes? Not sure how many
        Channels - auto
        Devices - PS4/PC hardwired, iPhone/Mac/iPad wireless
        How can I find the firmware you’re now suggesting?
  • To everyone involved I have set the channels to manual channels and am currnetly waiting to see if it'll happen again before I try changing the Firmware.
    • biancaj's avatar
      biancaj
      Guide
      Well, my issue started up again today, so the firmware downgrade didn’t help.
      • FURRYe38's avatar
        I would replace the router or ask NG support for an RMA...
