FirstCup
Nov 06, 2025Guide
IPV6 no connection RBR 850
I called my ISP and they confirmed I have an ipv6 connection available from them on a fiberoptic connection to my Orbi RBR 850 which will not transmit ipv6 to my network and when I run an online ipv6 test it confirms not connected.
RBR 850 firmware v7.2.7.15, I just read on the netgear site this firmware is a problem for ipv6 and to set back the firmware to a previous version. I have checked my router settings many times in the advance ipv6 settings, currently set to DHCP
any thoughts from anyone who has experienced problems with ipv6 connection issues would be greatly appreciated. Thanks,
It would be interesting to see a summary of which Netgear WiFi7 Orbi's (770, 870, 970) are known to support IPv6 (or fail to support IPv6) on each of the major Internet Service Providers.
i.e. Does IPv6 FAIL for the 870 on every ISP? Do 870's work on cable systems (Comcast, Cox, Spectrum), but fail on fiber systems?
- KMDonlonVirtuoso
I'm on Cox fiber, odd part to me is prior versions (before v7.2.7x.) worked flawlessly and has remained broken with the last 2 updates of firmware. Also the time frame seems a bit odd with such a major brand and the length of time for a repair...almost a year now...just strange they have been unable to sort it out.
- KMDonlonVirtuoso
Minor correction to my last post. 3 firmware versions, not 2 since IPv6 has failed to stay connected.
Broken using:
v7.2.7.15
v7.2.8.2
v7.2.8.5
IPv6 issues are known across ALL AX, AXE and BE orbi systems. Many ISP levels with the ISPs as well. We've made NG aware of the issues at hand and others have been working with NG on this. Seems to take some time and have no idea if or when a fix will be forth coming. All in the hands of NG. Users will need to keep IPv6 diabled for now while on newer versions of FW if they choose to run with newer versions of FW. Otherwise for AX and AXE series, and you want IPv6 working, can revert back to older versions of working FW which was reported by others for a work around for now.
We'll keep checking with NG on this.
Good Luck.
- KMDonlonVirtuoso
Looks like another firmware update posted, v7.2.8.5. Again, no mention of an IPv6 fix, just security updates :(
- KMDonlonVirtuoso
Following up on this...any word of an IPv6 fix coming?
Something to try and see if new FW has IPv6 working if your interested:
NOTICE: New - RBR850 / RBS850 Firmware Version 7.2.8.2 Released | NETGEAR Communities
any thoughts from anyone who has experienced problems with ipv6 connection issues would be greatly appreciated. Thanks,- KMDonlonVirtuoso
Not working :(
- KevinLiTNETGEAR Moderator
Hello KMDonlon,
Welcome to the NETGEAR Community!
I understand that you are having issues with your IPv6 connection on your RBR850 with firmware 7.2.7.15. This issue can be a result of using an older firmware version. Please try our most recent firmware for your RBR850 FW v7.2.8.2 then factory reset your system.
Please navigate to the download link below to download Firmware v7.2.8.2 for your RBR/RBS850 (Please be sure to update the satellite first):
https://kb.netgear.com/000070385/
For step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comPlease keep us updated on the progress of this issue!
Best,
Kevin
NETGEAR Team
- FirstCupGuide
Thanks guys,
My ISP is Hood Canal Communications on the Olympic peninsula. we were an unserved area until last year so a nice fiber optic was installed last year, very nice. my modem is an Adtran SN ADTN225050CD
not sure what you mean by downgrade the system? Understand the factory reset maybe. I do not follow to upgrade to v.21 FW. my current FW is v7.2.7.15 and shows it as being current where would I download the older FW from.
thank you
IPv6 is broke on v.15 FW, last known working FW was v.21. IF you want to try v.21 then you'll need to downgrade FW to v.21 and then factory reset and setup from scratch. Be sure to disable the auto update on v.21 so the system doesn't re-load v.15. Or just keep IPv6 disbled for now until NG and ISPs get this all figured out for IPv6. All up to you.
- KMDonlonVirtuoso
A firmware update has just appeared in the download area, no mention of IPv6 fix in the release notes though...just a security fix...
https://www.netgear.com/support/download/?model=RBK852
Its been an issue for a long time. And it's not just a Netgear issue, but an ISP issue. I have Xfinity, and it's not worked properly with an Arris, an OpnSense home-built router, or a Netgear. So while Netgear might be able to fix issues on their end, it's not just their issue.
There is a known issue with v.15 FW and IPv6 failing to work.
If you need IPv6, then you'll need to downgrade the RBS first then RBR lastly to v.21 FW as that version was last known working for IPv6.Once you have the system downgraded, please factory reset the system and setup from scratch.
Who is your ISP?
What brand and model# is the ISP modem/ONT?
