Vito0163
Feb 20, 2026Aspirant
Orbi 960 10gb port not reading high fiber speeds correctly
Orbi 960 10gb port not reading my 8gb fiber speeds. The max it will read is 5 gb down and 3700 up. I have tested it other ways using another router (eero max7) and directly out of the modem and everything else readys 7.8 down and up. Anyone else experiencing the same issue or know of a fix?
- Vito0163Aspirant
did you ever figure out a remedy to this? I am experiencing the same issue with the orbi 960 10gb port not reading out my 8gb speed correctly. I have eliminated every other possibility.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What speed are you seeing for the WAN port of the RBR connected to your ISP modem/ONT?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Are you speed testing with the onboard speed test on the RBR, Orbi app or a ethernet PC connected behind the RBR or wirelessly?
What brand and model# device are you speed testing with?
IPv6, Armor, SPC or Traffic Meter enabled on the RBR?
Using ISP detected DNS or custom DNS?
You should see to spec speeds on the RBRs speed test, however speeds at the LAN port would max out at 2.5Gb range since there only 2.5Gb on the one port. Others are 1Gb ports.
- Vito0163Aspirant
Orbi firm 7.2.8.2
optimum 6e max router fiber 8gb service
brand new cat 6a cables connected
on board orbi test is 4.7 to 5gb down and 3.7 gb up
I have tested with the optimums techs tester connected directly from the modem connected with the cat6- cable.
I have also went out and purchased the new eero max 7 and connected to the fiber modem and tested the speed using the app through eero which read 7.8 up and down. I also connected the 10 fb port from the eero to a 10 gb adapter to a mac and read 7.8 up and down.
Everything is is reading the same speed except the orbi 10 gb port- FURRYe38Guru - Experienced User
What Connection speed are you seeing for the WAN port of the RBR connected to your ISP modem/ONT?
And you're testing with netgears built in speedtest site?
You're a little caught because the inboard test site doesn't always pick the fastest server. And the 963 only has a 10g wan port. The max lan port is 2.5g. So you can't even connect a different device to it to test a different test server.My bet? Its not picking a decent server. The built-in one is flawed because you can't change the server, and it doesn't always pick the fastest one. It used to be a big issue when people were first getting 1 gig services and the test servers weren't fast enough to saturate the speeds. It got better with upgrades, but now people are creeping up on 5+ GB services and we're starting to see it again.
FURRYe38 's question is important.
The Orbi WAN port Is supposed to autonegotiate one of these speeds with the ISP device:
Autonegotiation is a feature built into the actual Ethernet hardware (not a user setting).
https://en.wikipedia.org/wiki/Autonegotiation
The router web interface should report that the speed negotiated is 10G (maybe 10000Mbps?) If it reports being connected at 5G, then that is the most data it will support.
So, it is either a cable issue or a compatibility issue between the Orbi Ethernet hardware and the ISP Ethernet hardware.
CrimpOn good point. Might be worth checking the connection link on the wan to see if its limited to 5g.
If the connection is negotiating 10 gb, then you should perhaps reach out to your ISP.
Assuming the WAN port status is showing 5 gb negotiation for the Orbi (and the Eero):
- What model is the modem (ONT)? It is possible that it might not deliver 10gb ethernet.
- Have you tried a different cable for the WAN port (at least cat 6)?
