SuperMario22922's avatar
Aug 26, 2026
NAT loopback fails for clients connected through RBE370 satellite
I’m using an Orbi RBE371 router with an RBE370 satellite, and I’ve found what looks like a NAT loopbackNAT issue.
NAT loopback works normally when a device is connected directly to the main router, but fails whenever the same device is connected through the satellite.
Tested behaviour:
  • Connected to main router over Wi-Fi: NAT loopback works
  • Connected to main router over Ethernet: NAT loopback works
  • Connected to RBE370 satellite over Wi-Fi: NAT loopback times out
  • Connected to RBE370 satellite over Ethernet: NAT loopback times out
Direct LAN access still works perfectly through the satellite.
For example:
curl https://example.ddns.net:8000
times out when connected through the satellite, but works through the router.
The hostname correctly resolves to my WAN IP, and I tested multiple forwarded ports with the same result.
Is there a way to fix this?
  • This looks like a satellite-specific NAT loopback issue. Since NAT loopback works directly through the RBE371 but fails through both Wi-Fi and Ethernet on the RBE370, the port forwarding and DDNS are likely fine.
    I’d check for firmware updates and any client isolation/routing settings. If there’s no NAT loopback option, using split DNS to resolve the DDNS hostname to the local server IP is a good workaround.
    • SuperMario22922's avatar
      SuperMario22922
      I'm on the latest firmware already and I don't think there are any settings related to that at least I can't find any on the settings page. The problem with the split DNS is that multiple local IPs are port forwarded like port 9000 and port 8000 go to different local IPs
    • StephenB's avatar
      SuperMario22922 wrote:
      I've only had this system for a few days is this not where the support happens?
      This is a user-to-user forum, not Netgear support.
      You get Netgear support from mynetgear.com.  You can use your forum credentials on that site, since Netgear uses SSO.  Register the Orbi (if it isn't already), and upload proof of purchase before opening a support ticket there.
  • StephenB's avatar
    For example:
    Sounds like that should work.  I am wondering you've tried:
    • disabling ipv6 in the client PC
    • testing with a port that isn't forwarded
    That might give some clues.
    Is there a particular service you need to get to work?  FTP with passive ports comes to mind.  But if that is the issue, you could potentially work around it by switching the to FileZilla client.
      SuperMario22922
      I have a few web services that are port forwarded and i can't access them locally because NAT loopback is not working
      SuperMario22922
      I don't have IPV6 at all and i tried multiple forwarded ports and none of them work on the satellite
      • StephenB's avatar
        How about a port that isn't forwarded?  That should normally work locally, but fail when remote.
