TOPS119's avatar
TOPS119
Luminary
Apr 14, 2026
RBE970 / RBE971 Firmware Version 12.1.8.7
So I have updated the RBE971 successfully but the Rbe970 satellites firmware fails, anybody else having this issue is the server down ?
    • TOPS119's avatar
      TOPS119
      Luminary
      Yes I am in the correct region, I did the update of the satellite first and it fail I tried the main satellite and that seem to work. so now the main router has the latest firmware while the satellites have the previous. not even sure what to do now.
      • FURRYe38's avatar
        Never mind.
        FYI, NG is pulling this version of FW. Seems this wasn't supposed to be released yet.
        So you have the RBS at v9 still and the RBR at v12? Let me know. We need to get you back to v9 FW.
    • FURRYe38's avatar
      Ok sounds good. You can use that in mean time.
      Will make sure NG posts next update correctly when they get ready for the 970 series. Think one hand didn't hand shake with the other correctly.
      • FURRYe38's avatar
        FW files are needed to downgrade.
        Does your system need downgrading?
        What region are you located?
        You have the 970 series system?
        mlfx wrote:
        How did you the downgrade?
