Artur2505's avatar
Nov 03, 2024
RBE971 iphone is keep disconnecting and room 15ft away no connection
I don't know what's going on but I had orbi 6e mash and never had any problems before
Room next to other room where is router connected, my phone is not working with wifi
Usually few times a day randomly disconnects
I have 2200 sqft
Router on 2nd floor connected to 10gb ethernet
1 st floor satellite around 30-40 ft away
Firmware VersionV9.12.3.3
  • FURRYe38's avatar
    Does this happen with the RBS turned OFF?
    What model iPhone do you have?
    What iOS is loaded on it?
    If the iPhone is a later model with 6Ghz support, try disabling 6Ghz feature on the phone and check for this problem...
    What channel configurations are currently set on the router?
    • Artur2505's avatar
      Artur2505
      Tutor
      I do not understand my firmware update on my router is up to date.When I'm checking on Orbi app no new firmware available
      Do I need to manually download and install?
      If yes should it be done thru website?
      Admin login?
      Artur2505
      Tutor
      Just to let you know ir doesn't seems like there was big improvement
      Still wifi works weird in a room that is next to the router
      When I'm downstairs it works way better when I away from router that in that room that next to the router
      Network restarts randomly sometimes without any reason just dropping connections and restarts
      Not sure what is going on but never had this issue with 6E previous router before upgrade
      Speed is better yes on this router but overall it doesn't work better than 6E version before
      Maybe in future it will work better maybe newer update will come out and fix it
      Im in USA
      • FURRYe38's avatar
        And you updated to the newest version of FW?
