1961theo
Feb 16, 2019Star
NETGEAR Nighthawk AX8 8-Stream AX6000 WiFi
why is it when i set my router in the Wifi Smart connect modus the signal is terrible ?
I bought this router in the hope that i had a good choise, but i wonder???
the internet is also spontan...
- Feb 19, 2019I use a MacBookPro , a Synology NAS 918+ Epson ET 2650 , Siemens oven😉, Samsung tv. IPhone, Ipad
Must say most of the times it works splendid. But combined with VPN in the Netgear Nighthawk AX 8 Router RAX80 it would be 👍🏼
DarrenM
Feb 19, 2019Sr. NETGEAR Moderator
can you give some more detail on when the internet does not work and what type of devices you are using.
DarrenM
