SAM_the_GAM's avatar
SAM_the_GAM
Luminary
May 29, 2020
New Firmware Released RAX80 1.0.3.88
Bug Fixes:
  • Fixes the issue where the wireless transmit power does not match the percentage set by the “Transmit Power Control” setting, which is on the of Advanced-Wireless-Settings page of the router web interface.
  • Fixes minor bugs.
  • Fixes security bugs.
New Features and Enhancements:
  • Supports NETGEAR Armor.
  • Supports NETGEAR Circle parental control
  • Improves the device type and model detection.
  • Supports the DHCP option 60/61 protocol for Internet.
  • Supports OFDMA for 2.4 GHz and 5 GHz separately.
Firmware Update Instructions:
Download Link: http://www.downloads.netgear.com/files/GDC/RAX80/RAX80-V1.0.3.88_1.0.41.zip
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RAX80.aspx#docs.
    • michaelkenward's avatar
      michaelkenward
      baileyj0611 wrote:
      My RAX80 will NOT upgrade to this.
      I'm afraid that "will NOT upgrade" doesn't help when trying to debug your problem.
      What are you doing and what happens when you try?
      • Retired_Member's avatar
        Retired_Member
        I've been lucky as my RAX80 has been flawless behind an CM1000 modem.  Now since the .88 update, I've has constant internet drops.  I guess it's my turn now.  Doing a factory reset is the only way to get the internet back but it doesn't last long.
  • Good step in the right direction! This update did bring some performance gains to my router, that is always welcome. The biggest thing i appreciate is the additioins to the UI. We need more control over this awesome device! Please keep working on this devices firmware, it has all the power now we just need the control! I upgraded from the R7000 and that thing had more granular control than this router. Give this router more attention regarding the UI (web UI), people who will be/are buying this device are power users for the most part and giving those users what they want and need will make this a much more attractive product.
  • Just want to chime in with my experience using 1.0.3.88 for the last few days. From the client side it has been great, my wifi 6 units have been working flawlessy with WPA3 enabled. in short, no dicernable disconnects etc to report from the end user point of view.
    When digging a little deeper the RAX80 still present some peculiarities, though. First a little about my setup: Internet -> ISP provided cable modem/router in bridge mode -> RAX80 (with AX, OFDMA & MU-MIMO all enabled) -> Netgear MS510TX switch connected to all wired clients. For further context; I live in an appartment building with around a dosen networks "fighting for supremacy", but using wifi 6 and a channel without much congestion wifi has been stable.
    Now the peculiarities:
    • The "Show statistics" page on the advanced home screen still show intermittent WAN drops/reconnects (about once every 24 hours). Strangely I have yet to find corresponding log entries in the ISP modem or the RAX80 log.
    • The connected LAN port also seems to reconnect/drop from time to time, albeit less frequent than the WAN port. No log entries for these drops show up in the router log, nor the switch log either.
    • Trying to disable the "inlude known DoS attacks and Port scans" log category results in a ERR_CONNECTION_RESET page when clicking apply.
    • The "Attached devices" page is clearly an improvement, yet I still find it somewhat unpredictable. Devices seem to linger in this list long after they have been turned off/disconnected, even after pressing refresh several times. Also, depending on how you view the list (router web view or Nighthawk app), the number of devices may also differ.
    I have no idea if the log or the statistics view are correct, but there are clearly some discrepancies between them. In general this firmware release has been nice, just some oddities evident for the network tinkerers among us.
    • magfred's avatar
      magfred
      Guide
      I forgot to mention that I also did a factory reset after upgrading.
    • mjc775's avatar
      mjc775
      Luminary
      Your post inspired me to check my "Logs" - the first time since I installed the RAX80 3 months ago. It includes various "DHCP IP" entries for the past 2 hours or so, then the remainder of the log is hundreds of entries of "Wednesday, Dec 31,1969 16:00:00" with no other data listed.
      Is anyone else seeing this?
      BTW, I'm still on FW V1.0.1.70_ I came to this thread to see if I should do the update. For the most part I've been very happy with my current firmware, speeds and reliability other than an occasional random reset every 2-3 weeks.
      • I'm now running this firmware with ZERO issues - Hooked up to ATT GIgapower 1gb/1gb connection - consistent at 940 both ways.
        network storage functionality working perfectly *knocks on wood*
        I did however have to set WAN to DHCP to grab an IP from the att box, I htink it's something to do w/their **bleep**ty Pace modem - It doesn't like to run DMZ plus mode that wall - It sort of worked, btu had DNS issues.
  • This new firmware has been problematic on my rax80, which was generally working fine beforehand.  The big problem is the need for factory resets.  I had to factory reset after the firmware installation itself.  Annoying, but workable.  I had a power outage tonight, and when the power came back on my router was doing the same thing it was after the firmware install.  I had to factory reset again.  If I have to factory reset every time the power goes out, this thing is going to get thrown in the trash pretty quickly.
  • Any idea why factory reset is necessary after firmware update?  Seems a bit extreme.  I also have a EAX80 and an EX7700...will I need to reset the extenders as well?
      michaelkenward
      It isn't always. But updates sometimes introduce changes that are not compatible with older settings.
      This is also a support call of last resort when people have problems. "Do a factory reset". Sometimes it works, but often not.
      You can always back up your settings before you reset. If that doesn't fix problems, you can then restore the settings.
      • Orts001's avatar
        Orts001
        Mine bricked itself after the upgrade from 1.0.2, did a factory reset and tried restoring the settings, same thing...
  • I have (only) 27 devices on my network, 4 WiFi 6 and 7 wired.
    This release works allows home automation to work blazingly fast and the cooling fan to kick in.
    Apart from reformatting USB drives to NTFS, which works perfectly, no special settings to allow it to work really well. Very happy vs previous firmware.
    I did can the Armour and Circle options, enabled AX and ODFMA on both radios, WP2&WPA3.
    Not being a smartass but maybe full reset and one issue at a time works.
    • Nmouneimne's avatar
      Nmouneimne
      Apprentice
      Are you able to transfer large files (3GB or more) to the USBNetword drive?
      How are you speeds compared to the last firmware?
      • pir4tedirk's avatar
        pir4tedirk
        Tutor
        Large number of files large batch no problem, most files around 2-6 Gb from Mac to NVMe 3.1 interface formatted NTFS.
        Seriously fast network, fastest ever been on. All devices though this one router, one fast switch for entertainment hub.
    • thedge's avatar
      thedge
      Tutor
      Smart ass?....no worries...I think you were making a good suggestion. I did the reset a few days ago and it was a “pain in the ass“ for the better part of the weekend. Things are working fine now.
  • Firmware Version V1.0.3.88_1.0.41
    Installation:
    The update wasn't available in the router so I downloaded it from Netgear and installed manually.
    After installing and reboot, it was unresponsive, so I had to shutdown and do a cold restart. Some of my settings--like my DHCP range--were reset and caused some minor difficulties but that's why I have a network spreadsheet with all my MACs and IPs to validate my settings.
    The only things it seemed to erase were a.) the DHCP range; b.) possibly two port forwards, but since I only keep port forwarding up when I'm actively using them and erase them when I'm done, it's possible I'd already erased them; c.) some of my names from both the LAN setup page where I assigned IPs and Access Control under Security. But...Nighthawk firmware was doing that before and it might have been the earlier firmware. Right now I'm renaming everything and making a date entry in my spreadsheet to start the clock how long it holds everything.
    I've only begun initial testing--my job, which is software testing, kind of got overwhelming--but below is what is working and didn't used to.
    Opinion: I reserve the right to complain later, but as of about a weekish of use, this is infinite+1 improvement.
    So far, awesome:
    1.) My speed is still fantastic, but that's the only thing that ever worked and the only thing that made me not replace this router and then burn it beneath the new moon covered in goat's blood. The speed has always been fantastic. It's still fantastic.
    2.) My USB shares now stick around. Like, all the time.
    Context: I just got a Nvidia Shield TV Pro and moved my Plex server from my Pi to it along with the drive enclosure with all my media drives. The Shield dead refused to recognize my drive when I direct connected with USB, so I temporarily connected it to the Nighthawk router before the update just for testing Shield's Plex server. Of course, the router kept forgetting th9se rives existed. I was preparing to move the drive enclosure to my home server and mount it to the Shield from there (which I was trying to avoid), but between work and everything, I didn't get to check it until a few days after the update.
    All my shares were showing in Plex on the Shield and all my libraries were up to date; the shares showed on my LAN and were accessible from my laptop, my server, my son's PC, and my Pi. I hosted a movie night online for friends and everything worked. Friends with library access report no problems. I check at random and the usb shares are right there.
    3.) The Attached Devices screen is shockingly accurate as type of item; also, it now knows there are items that are not iPhones or Macs. It correctly recognizes my doorbell, a few smart speakers, my computers, my phones, my tablets as far as icons go, and got a surprising number of IoT items right. But now I have to categorize my four network switches as router since switch isn't on there, and my three AP routers as routers as well. Any suggestions on how to categorize them correctly? They're hardwired into the LAN; do I call them extenders?
    4.) Names that were there right after I updated the firmware seem to have stuck, but I'm fixing all of them and their model names now and will report how long they stick.
    5.) I don't think I'm imagining the layout fixes on some pages?
    So far, weird:
    1.) On the Attached Devices, the sort order is--weird?  I have no idea what the sort is, but even after I switch it to IP address, it defaults back to whatever it's using now.  Annoying, but happily, that's my biggest complaint.
