mpjjd's avatar
mpjjd
AC1750 Model C6300 WiFi connection
Just purchased the C6300 cable modem router and pretty much any time I try to connect a new device on WiFi, the WiFi connection drops for all connected devices and the modem has to be rebooted.  After rebooting, I can connect the new device and everything reconnects fine.  If I try to add another device after an hour or so, the same problem occurs.  I reboot the modem and I can connect again.  This has happened at least 5 times in 2 days, so it isn't a coincidence.  I am a Comcast customer and when this happens, the internet connection is not lost (so my ethernet connected devices continue to work).  It is a router issue.  I'm on firmware version 2.01.14.
I know there are a lot of reported similar issues, but I haven't seen a solution yet.  Hoping someone out there can help.
Thanks.
  • I just purchased a C6300 and have the same connection issues as described in messages above. How do I resolve it?
  • I am having the same problem.  I recently purchased a Dell XPS and when I try to connect my laptop up to the modem the connections go dead.  I have to reset the modem and it will work for about an hour and do it again.  I have several other devices that are connected and it works fine but when I try to connect to the computer it drops everything?  What do we do?
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello Shilfker
      Have you made sure you have the latest network drivers for that pc?
      DarrenM
  • DarrenM's avatar
    DarrenM
    Hello mpjjd
    When you say make a connection are you meaning when a device that already knows the network powers on or when you connect a new device all together?
    DarrenM
    • mpjjd's avatar
      mpjjd
      When I connect a new device.  Once the first connection is made, reconnection is fine.
