hsustyle's avatar
hsustyle
Initiate
Aug 03, 2016
c6300 keeps dropping connection
I just bought the c6300 cable modem router to use with Comcast xfinity internet service.  I followed the quick installation and activated with Comcast.  Now my experience is that every day at random times, the wireless connection will dissapear.  I will no longer be able to see the wifi signal for either 2.4 or for 5g.
Things that resolve the problem:
 - resetting the modem
 - restarting the modem
 - turning off the wireless radio and then turning on the wireless radio again
Then when the problem is resolved.  After a few minutes or after a few hours, the wireless signal will drop again.
Unfortunately, none of these are solutions solve the problem permenantly as I need to have consistent wireless signal and cannot be resetting things constantly.
I have spent over an hour with Netgear support on the phone and have changed the channel to 01 and the problem persisted.  I was not able to be connected to a supervisor.  My case number is 27232197.  Firmware is V2.01.14
If I cannot resolve this problem in the next few hours, I will return the product as it is not dependable and this product and customer service experience has severely tarnished my perception of the Netgear brand and products.
Any suggestions on how to resolve this problem are greatly appreciated.
Other information:
Devices in our household: PC laptop on Windows 10, Mac laptop, Android smartphone, iPhone, iPad, Kindle
Firmware:
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello hsustyle
    Have you been able to resolve the issue with the wireless or is it still happening if so let me know I will be able to get your case to the right person to help.
    DarrenM
    • cybrmstr's avatar
      cybrmstr
      Tutor
      I am also having this same issue.....ive had the modem about a year or so.  It wont run to completion any trace route.  Drops the connection all the time recently.  By recently I mean like the past few months.  Never had a problem till now.
      • DarrenM's avatar
        DarrenM
        Hello cybrnstr
        Are you seeing anything in your cable logs when the drop outs are happening? if so could you copy and paste them.
        DarrenM
    • freeradical2's avatar
      freeradical2
      Can you help me too please, i have been onto Netgear and Comcast about this and both are blaming each other.
      • DarrenM's avatar
        DarrenM
        Hello freeraical2
        When the drop outs happen can you log into you modem and copy the logs you can find them under Advanced-Administration-Logs.
        DarrenM
      • DarrenM's avatar
        DarrenM
        Hello hsustyle
        Thanks for that suggestion.
        DarrenM
  • DarrenM is the netgear moderator and he's telling you to contact them because it's under warranty. I contacted them while my unit was under warranty. However while its under warranty for a year they will only provide technical support for 90 days. Which is ridiculous and awful customer service. The guy at customer service told me it was "broken network protocols" and yes they could fix but it would cost $150
