702dani's avatar
702dani
Guide
May 26, 2021
C7800 Access Denied / No Wifi firmware update
Bought the C7800 a few days ago. Connected, setup - worked great for a few days with Xfinity 1GB plan. The app said “firmware out of date” and to login to admin to update, but there was no option. Support said ISP updates the firmware. Current firmware run is V3.01.43. Power cycled the unit about 5 times, nothing. Cable connection shows Aquire Downstream Channel - Locked, Connectivity State - Access Denied. I called Xfinity and they can see the modem online and set up correctly, but have no answer to why it is not working. When I logged into admin (Netgear genie) it said firmware updating, but then disappeared.
A day later and neither Xfinity nor Netgear tech can figure out what is wrong. Help please!
  • plemans's avatar
    The firmware for the C7800 is built into the partitioning file from the ISP when the set it up. so they one they have, is the one you'll get.
    To try to get it working, try this.
    Disconnect everything from the C7800 including the coax cable. (leave the power cable)
    While powered on, push and hold reset for up to 30 seconds. let it reboot.
    Once fully rebooted (all light stablized), then power it down, wait 2 minutes, connect the coax to it, and power it back on.
    Wait a couple minutes for it to fully boot.
    then attempt to access/set it up.
    • 702dani's avatar
      702dani
      Guide
      Thank you for the advice! It did not work. Unfortunately it is the same, bit sure if it has to do with the file from the ISP. But it is locked on downstream and shows Connectivity - Access Denied. Xfinity tech support says they can see the modem online. However the Nighthawk app still says “Firmware out of date” (it always has, though, even when it was working perfectly. I am wondering if Xfinity is just not compatible with this model?
  • Did you get it fixed ? I am having the same issue , same model and the app says the same thing
    • 702dani's avatar
      702dani
      Guide
      I did! But it turned out to be nothing with hardware. It was a cabling issue outside with Xfinity. Their xFi gateway had caught signal for a moment while troubleshooting, but it was only luck.
      Unfortunately we did have to have a Comcast tech out. Hoping we aren’t charged for them having to fix their own wiring issues!
      • FURRYe38's avatar
        Please mark your thread and solved so others will know. :smileywink:
  • Bought router 4 days ago. Spent two days on phone with BOTH Comcast and Netgear. Verified with both companies my firmware is most recent (V3.01.43). However, Cannot finish app application. FINALLY Netgear admitted it's their APP. When will this PROBLEM be corrected? Any other help appreciated.
    • FURRYe38's avatar
      Use a wired PC and web browser and setup the modem using the modems web page.
      • Wirhwings2002's avatar
        Wirhwings2002
        Tutor
        Wont work. My NEW laptop does NOT have an ethernet connection. Can this be done using an USB port connection?
