Svalent
Nov 10, 2020Tutor
CAX80 connected but no internet Xfinity
I just recieved the CAX80 yesterday and called Xfiinity to get it hooked up. It's online but I can't connect to the internet. Xfinity confirmed that it is working on their end. My phone shows that it is connected to wi-fi 6 and has good connection but there is no internet. How can I get this to work? I'm about to return it.
- SvalentTutor
I also tried connecting to the nighthawk app and can't do that either without an internet connection.
Does a wired PC connected to the modems back ports work?
Try a factory reset and setup from scratch using a wired PC.
Be sure your mobile devices is setup for automatic IP addressing configuration. Not static on the mobile device.
- SvalentTutorI haven't tried hooking up to a wired connection yet. I'll try that when i get home today
When you connect a wired PC, use a web browser and access the modems web page at 192.168.100.1
I'd check the wireless SSID name and PW and check the status on the Basic and Advanced Tab home page as well.
log into the cax80 through the browser. Get a screen snip of the cable connections page and the logs from the router.
that helps us to check the connection back to the isp.
also, try factory resetting it, (push and hold reset for 7-15 seconds while powered on). After it reboots, power it back off, unhook the coax and leave it for a minutes or 2. Then connect the coax back to it and boot it up, try reinstalling it.
If that doesn't help, post the screen snips of those logs and cable connections page.
did you call in for setup or use the autoactivation?
- SvalentTutorHow do i login through the browser? I'll try your factory reset idea. I called xfinity to get it setup and they activated it and said it was working. Then we hungup. I tried logging into wifi on my phone and it kept wanting me to sign into the comcast network. So i called them back and they said they had to turn on the internet and reset it. So it let me put in the network password after they did that and the modem was online and i was showing good connection. It just said there was no internet. They reset the modem from their office, i restarted my phone a couple times, they reset the network and none of it work. They suggested i get ahold of netgear tech support because xfinity is working fine on their end.
- SvalentTutor
So I did the factory reset and then disconnected everything and plugged it in and hooked up an ethernet to my laptop. At first the internet still didn't work even though it was hard wired. I logged into the modem and was just going through the menus and then after about 5-10 minutes I tried the internet again and it was working. Youtube was working. So I logged in with my phone and wifi is now working on my phone. Here is a copy and paste of the cable log. Now I'm trying speed tests and I'm not impressed. On 5G on my phone it was a little over 100mbps download speed and each time I test it, it is getting less. I have the 1000mbps plan from Xfinity so I should be getting a lot better. I ran the speed test on my laptop and it is hard wired and download speede was 434. Then I tested again a few minutes later and it was 104. I just tried again and now I got 460. shouldn't I be getting at least double that? should I reset the modem again?
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 447 MHz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked 256 QAM 8 447000000 Hz -2.0 dBmV 40.6 dB 0 0 2 Locked 256 QAM 9 453000000 Hz -2.6 dBmV 40.5 dB 0 0 3 Locked 256 QAM 10 459000000 Hz -2.4 dBmV 40.5 dB 0 0 4 Locked 256 QAM 11 465000000 Hz -2.8 dBmV 40.3 dB 0 0 5 Locked 256 QAM 12 471000000 Hz -3.0 dBmV 40.2 dB 0 0 6 Locked 256 QAM 13 477000000 Hz -2.6 dBmV 40.3 dB 0 0 7 Locked 256 QAM 14 483000000 Hz -2.5 dBmV 40.4 dB 0 0 8 Locked 256 QAM 15 489000000 Hz -2.2 dBmV 40.5 dB 0 0 9 Locked 256 QAM 16 495000000 Hz -1.6 dBmV 40.7 dB 0 0 10 Locked 256 QAM 17 507000000 Hz -1.4 dBmV 40.8 dB 0 0 11 Locked 256 QAM 18 513000000 Hz -1.4 dBmV 40.4 dB 0 0 12 Locked 256 QAM 19 519000000 Hz -1.2 dBmV 40.5 dB 0 0 13 Locked 256 QAM 20 525000000 Hz -1.0 dBmV 40.8 dB 0 0 14 Locked 256 QAM 21 531000000 Hz -0.9 dBmV 40.8 dB 0 0 15 Locked 256 QAM 22 537000000 Hz -1.1 dBmV 40.8 dB 0 0 16 Locked 256 QAM 23 543000000 Hz -1.2 dBmV 40.6 dB 0 0 17 Locked 256 QAM 24 549000000 Hz -0.9 dBmV 40.7 dB 0 0 18 Locked 256 QAM 25 555000000 Hz -0.7 dBmV 40.8 dB 0 0 19 Locked 256 QAM 26 561000000 Hz -0.8 dBmV 40.8 dB 0 0 20 Locked 256 QAM 27 567000000 Hz -0.9 dBmV 40.8 dB 0 0 21 Locked 256 QAM 28 573000000 Hz -1.0 dBmV 40.7 dB 0 0 22 Locked 256 QAM 29 579000000 Hz -0.9 dBmV 40.6 dB 0 0 23 Locked 256 QAM 30 585000000 Hz -0.4 dBmV 40.7 dB 0 0 24 Locked 256 QAM 31 591000000 Hz 0.0 dBmV 40.6 dB 0 0 25 Locked 256 QAM 32 597000000 Hz 0.1 dBmV 40.5 dB 0 0 26 Locked 256 QAM 33 603000000 Hz 0.1 dBmV 40.6 dB 0 0 27 Locked 256 QAM 34 609000000 Hz -0.2 dBmV 40.4 dB 0 0 28 Locked 256 QAM 35 615000000 Hz -0.3 dBmV 40.3 dB 0 0 29 Locked 256 QAM 36 621000000 Hz 0.0 dBmV 40.3 dB 0 0 30 Locked 256 QAM 37 627000000 Hz 0.0 dBmV 40.4 dB 0 0 31 Locked 256 QAM 38 633000000 Hz 0.0 dBmV 40.3 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 4 5120 Ksym/sec 36700000 Hz 42.0 dBmV 2 Locked ATDMA 1 5120 Ksym/sec 17300000 Hz 43.3 dBmV 3 Locked ATDMA 2 5120 Ksym/sec 23700000 Hz 42.5 dBmV 4 Locked ATDMA 3 5120 Ksym/sec 30300000 Hz 42.5 dBmV 5 Locked ATDMA 5 1280 Ksym/sec 41200000 Hz 45.8 dBmV 6 Not Locked Unknown 0 0 0 0.0 dBmV 7 Not Locked Unknown 0 0 0 0.0 dBmV 8 Not Locked Unknown 0 0 0 0.0 dBmV Downstream OFDM Channels
Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 48 850000000 Hz -3.82 dBmV 39.4 dB 1108 ~ 2987 27482454 22121270 0 2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power
Current System Time:Tue Nov 10 16:46:59 2020System Up Time:00:17:23
Are you using smart connect? if so, the cax80 might have your iphone on the 2.4ghz which is much slower and sensitive to interference.
On your laptop, how are you testing? Many sites won't saturate gigabit. try speedtest.xfinity.com
Also, what laptop are you testing on? some older devices won't saturate gigabit.
