patricia2626's avatar
patricia2626
cm1000 modem 3.1
has any one test it from xfnity 1000 plan and tv cable has any one heard anything of it or review and will this works for tv cable and is there any erros or devites i need to look out for as my services makes me have two modems to get services
  • Hello patricia2626
    This is a cable modem only so it will only handle cable internet.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello patricia2626
    DarrenM
    • Trikein's avatar
      Trikein
      Luminary
      FYI to OP and Moderator. The CM1000 is not compatible in some areas depending on the infractrure(CMTS) in the area. As per user telcodad, who appears to have engineering background:
      "The CM1000 was certified on the older CBR8 code. Cisco later issued a code update to support their new D3.1 line cards, so MSOs can't rollback to the old code now without removing those D3.1 line cards."
      See full thread here.
