mr_sf
Oct 15, 2019Aspirant
cm1150v wall mount?
Can the CM1150v base be removed?
Don't worry... if I remove the base it will be properly ventlated on all sides. I just want to confirm the base is removable
thx
i don't have a cm1150v but both my cm1100 and cm1000 have a torques screw on the bottom that could be used to remove the base. It probably voids your warranty as they really do need that position for airflow or they'll overheat.
- EfficcialAspirantWere you ever able to find a wall mount??
- mr_sfAspirant
No.... i just ended up taking the base off and having it stand up on a wall mount wire hanger meant for ties. the cables are easily routed through the bottom of the hanger. not elegant, but seems to work. actually has a little air flow on the wall side.
