Pokemaniac's avatar
Pokemaniac
CM1200 slows down after 24-48 hours of uptime when using link aggregation
If I hook up my CM1200 to my router (an Asus RT-AX88U) in Link Aggregation mode, it seems to be consistenly slow down to only around 66-ish% of the full connection speed after somewhere between 24 and 48 hours of uptime.  The only thing which seems to fix this is rebooting the CM1200.  Additionally, I've had it running for at least a week now with Link Aggregation disabled, and I'm not seeing any slowdown, so it would appear that Link Aggregation is related to the problem.
The firmware of the CM1200 shows up as V1.01.02, for reference.
  • Having the same problem here. Opened a support ticket when first purchased but got the run around from net gear blaming Comcast for the issue. I have the rax120 router with cm1150 modem with latest firmware on both. I can confirm same findings, modem reset fixes issue after 24 hours of speed decrease. I wish netgear would fix this issue. I can also see that single wan on gigabit shows download of 940 and wan aggregation brings it to 1190. So it does benefit the gigabit connection. Netgear, please fix. All my channels are locked and signals are perfect in cable modem GUI also.
  • I have a NETGEAR CM1200 (firmware V1.02.02) modem, RAX200 (firmware V1.0.1.10_1.0.40) Router, Ubiquity US-XG-16 (firmware 4.0.69.10871) Managed Switch,  Comcast Xfinity 1gbps in San Francisco, CA, and can confirm I also have this issue.
    With LACP-IEEE 802.3ad enabled, I get between 980Mbps-1150Mbps for 12-18hrs, then speeds drop to 28Mbps-32Mbps.
    I began hard rebooting my router when it first arrived, and I thought the problem was with Comcast until I got to this thread. I then disabled LACP, et voila, 850Mbps-960Mpbs without reboots every 12hrs.
    Rather annoyed, as the one of the primary reasons for purchasing the CM1200 and the RAX200 was the touted agreggation, both for line saturation and redudancy. I would really appreciate a fix here NETGEAR.
    • Blake2423's avatar
      Blake2423
      I’m have the same issue. Bought the cm1200 and an ax8 router to leverage link aggregation to support future speed increases. Every 12-24hrs though speed drops to 25mbps. Really hoping there’s a fix for this soon.
      • FURRYe38's avatar
        If users don't want to wait for the ISP fix to come thru, users can try a CM1100. This model modem doesn't have this problem.
  • CM1200 modem, AX12-RAX120 router, 1Gbps download Comcast Bay Area setup here. Having the same issues as everyone else with Link Aggregation Control Protocol. Hopeful that Netgear support is working on this and will provide a fix in firmware.
    • L3XANDR0's avatar
      L3XANDR0
      I upgraded to a WiFi 6 router with a 2.5 gbps port, and I am no longer seeing a slowdown. I wasn't using link aggregation. The router is the Asus Rapture AX11000.
    • ray102382's avatar
      ray102382
      Still no luck? I dont want to have to replace the modem. But at this point its not worth holding out.
  • Is this ever going to get fixed or did Netgear just give up on their top tier modem?
    • shnushnu's avatar
      shnushnu
      Initiate
      Holy cow, its end of april 2020 and i just got this and the $1000 wifi6 orbi setup and i'm seeing the exact same link aggregation throttling everyone has...  How is this not fixed as yet?
      • DirtyPatriot's avatar
        DirtyPatriot
        Guide
        Same here this is shocking for a huge company like Netgear. they need to do some PR work here.
  • Firmware V2.02.05 appears to fix the issue. I've had link aggregation set up for about 16 hours now and no issues. Previously the speed would have reduced after 2-3 hours.
    Cm1200>RAX120
    • FURRYe38's avatar
      Please report your findings in another day or two...
      Cm1200>RAX120
        DirtyPatriot
        Guide
        I've been stable for 5 days now. Have been running speed tests every evening. Still pulling 1200down 42up. I am considering this issue finally resolved. Crazy it took a year but grateful nonetheless.
  • FURRYe38's avatar
    Any progress on this for you? New FW seems to resolve this.
    • flynhawaiian's avatar
      flynhawaiian
      Star
      now if netgear would just push the firmware update to something we purchased it would be nice, or provide us with a discount for the purchase of a new unit.
      • anthonypants's avatar
        anthonypants
        Tutor
        Netgear can't push this firmware down to your modem, that's your ISP's job.
        And don't bother calling your ISP to complain about it, because those CSRs will tell you that flashing firmware is your job.
    • Topology's avatar
      Topology
      Virtuoso
      Are other community members seeing a CM1200 firmware upgrade to V3.02.01 with Comcast/Xfinity?
      According to this thread, the new firmware enables upstream OFDMA channels – and, was installed on users’ CM1200 modems by Charter, only to be subsequently downgraded.
      • retate's avatar
        retate
        Star
        My CM1200 (Xfinity gigabit service in the St. Paul, MN area) is on V2.02.05 and has been rebooted today due to a 10% to 20% packet loss. It has been on V2.02.05 since the rollout a few weeks ago with no problems until today.
