My Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet.
My new Netgear C6300 wifi modem gives me only 75mbs when i use wifi and 300 when i use ethernet cable.
I have TWC 300 mbs conection.
I dont know why i get only 60 - 75 mbs in wifi even being close to the wifi modem.
Any help please????
i want to get at least 200mbs using wifi
- VE6CGXMaster
Two things, on which band? Are you using -ac mode WiFi card? Always WiFi speed is less than that of wired connection but your case is too much different. Did you set up the wireless configuration properly?
- nicosia2013Aspirant
hi ve6cgx and thanks in advance.
im very bad in computers matters.
i have conected to my wifi modem my mac book
i dont know which band iam using, how can i get that info?
i didnt set up or change anything, just conected and called TWC and they activated my modem.
Should i change the wirelles configuration? i notice that i have a 5ghz wireless too, should i use that one?
thank you.
- VE6CGXMaster
Usually having different SSID between 2.4GHz and 5GHz band is good idea.
- Moleary619Aspirant
Having a very similar problem here, getting over 300 Mbps on ethernet but 40-50 on wifi with a Netgear c7000. Also I can see my 5G on my phone but not on my laptop. The laptop is a Acre Aspire E1-737 and has a Qualcomm Atheros AR956x Wireless Network Adaptor if that helps. Any input or help would be much appreciated, thanks for your time.
- VE6CGXMaster
I think that card is basic single band -b/g/n WiFi card. Many low end budget laptops have them . But there is a possibility to upgrade it with better card if you are handy so you can open the laptop and take a look first.
I was thinking that was the case, but I know it can go up to 150mbps Link speed at least but its stuck at 65 now, any way to change that back?
