JustFRUSTRATED's avatar
Jan 17, 2017
NETGEAR AC1750 / C6300 wifi cable modem router LAN connectivity problems
HELP ... router has been connected since August without any issues, I bought a new lap top and in net genie on my old laptop (where I am typing this) it shows up and looks connected, I go to my new laptop put the network name and password (it is a protected network) and it states I will need to input more info go to webpage I Get a black and red NETGEAR page saying denied access.  I go to netgenie ON THIS LAPTOP and left click go through the whole bit, every tab etc and there is nothing no where that shows access/deny access where I can turn it on or off.  I have not logged into net genie since August so something is up.  ALL pw's network names/ssids are correct and match.  I adced the network on new laptop ... and it is not connecting to the web.  HELP.  I have no idea about any of this ... (I did do all the ipconfig command prompt things too, to make sure that was not the issue) WHAT DO I DO ... Please if you can instruct me thru the net genie thing that is all I have any knowledge of.  I AM SO PISSED OFF so any and all help would be so greatly appreciated you have no idea.  THANKS.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    It may be a wifi access list log into the C6300 and go to Advanced-Advanced Setup-Wireless settings and hit access list and try adding the mac address of the PC that will not connect to the network and see if that corrects the issue.
    DarrenM
    • JustFRUSTRATED's avatar
      JustFRUSTRATED
      Darren,
      Thank You.  I will try this when I get some time tomorrow and see if it works.  I did some more research and was thinking maybe I had to call my cable company for some info but this may do the trick.  Please check back in a day or two as I will report whether it works.  Again, THANKS SO MUCH.
