Kakashi2000
May 16, 2019Star
next gen cablem modem ideas 2020
next gen cable modem ideas 2020
netgear is time for make gaming cable modem many years have been past and still the cable modem having problem with the performance and software fimware problems
is time to make a next generation cable modem with a gaming software for real gaming
cable modem ideas
1.ddr4 1GB memory ram or higher for better reponce for software and multitasking
2.next gen secure 8 core cpu with fast clock speed with vapor chamber to reduce heat cpu
3.new next gen profecional gaming secure firewall 2020
4.next gen TLS 1.3 with the most advance security cryptographic algorithms for cpu and hardware and all the areas to prevent vulneravility
5.next gen ultra fast wifi with hardware security anti exploit to prevent hackers bypass the security or steal intenet even wifi is turn off
6.next gen 10 lan ports ultra gigabit 10,000mbs speed all lan ports
7.next gen secure ultra gaming vpn with all features
8.next gen secure port forwaring and portrigering to prevent network attack when you are suing gaming console or other device
9.secure DMZ
10.next gen secure encription Login webform to enter to the cable modem why this becaus emost cable modem login securty are extremely weak and hackers can bypass the scrips login webform
11.secure scrips software protection and laguage code to prevent malware or hacker bypass or damage the scrips of the modem or modifie it to leak information or to infect it
12.secure fimware encription security
13.dns securty protection
14.lan https or highter securty protection for lan ports network and wifi network
15.next gen ultra fast nat and solid protection nat
16.next gen ddos and ddos attack protection
17.anti mac device cloning to prevent hackers cant clone your device
18.new and allow and deny funtions for firewall and all type of connection for solid security
19new network monitor usage so you can see all apps and programs running in real time so you can block it or allow it and see how much data is using this can help to ideantifie new malware or hidden computers on the sistem so you can block or or ect
20.new tech protection network to detected swiching in gaming when this tech detect it remove the lag swiching the other gaming players is doing in the game allowing you to run normaly and not been affected when other player use haking tools to do network lag swiching in the game or try to boot you of the game
21.ultra fast Qos technology
22.new turbo firewall to play game safe and not been affected by firewall delay performance
23.new network tech aceleration pakage
24.new modern and beutiful design progaming cable modem
25.new wapa 3 secure
26.new neduma sofware
27.next gen cox technology 5,000ghz
28.real time voltage and parameters of downtream channels and upload channels for extreme performance with 64 download channels and 64 upload channels with the most advance tech with dosics 3.1 or 3.2 for both
29.next gen ultra deep ultra fast port scan
30.new gen network protection for all attacks and moderns attacks
31. make sure this gaming cable modem have a deidcate gaming motherboard
32. make sure you can update the fimware cable modem so dont be vulnerable
33.new next gen secure unpnp
34 next gen chip that allow ping to be extremely reduce for gaming and reponce ultra super fast
35 just make the best pro gaming cable modem ever made in the history of the netgear corp for 2020
36. make sure the cable modem run 10,000download and 10,000mbs upload
make sure you use is modern tech and dont use intel cpu the reason is theyre are vulnerable find other provider like samsung cpu or amd cpu i think they are more secure
intel cpu have alot of vulneravility we need a secure cpu or the cable modem will be a waste of money been vulnerable
10-4 out just helping to make gaming better
1 Reply
Gaming and desires like that are kept to the router product line. Like the RAX and XR. If you want a good modem, the recommended mode is a stand alone only modem. Then connect a external router ot that modem.
One reason why having a combo modem like this would not be great, should the modem fail for any reason, you would loose the entire unit, when having a stand alone modem and external router, you wouldn't loose the router should something happen.
NetDumaOS will only be on XR series routers and NetDumas R1 router.
Broadcom would be best for chipset instead of Intel.
You should post this here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Good Luck and best wishes though.
