FURRYe38's avatar
NOTICE: CM3000 cable modem v6.01.04 Firmware Released
Getting some reports that this version of FW is being seen on CM3000 series modems from CC/XF ISP. Not sure if other ISPs will be seeing this. Maybe at some point.
This seems to follow up on last years v.03 FW that was a bust and was pulled from use by the ISP and NG which resulted in users modems being downgraded back to prior v5 working FW.
Anyone seeing this, please give feedback on your experiences seen with this version loaded on the CM3000 modem.
Hopefully good results.
  • The CM3000 is connected directly to a TP-Link Omada Gateway/Router model number ER707-M2 into the 2.5G port. It then goes into a TP-Link Omada POE Switch model number SSG2218P. All TP-Link hardware is managed by an OC220 Controller and all firmware is updated by TP-Link to the latest as of 12-August-2026.
  • And my apology, but the firmware version is:
     Cable Information
    Hardware Version1.01
    Cable Firmware VersionV6.01.04
    • FURRYe38's avatar
      Ok, Looking at your power levels, seem a bit all over the place on the upper side across channels. A couple channels are on or near the max for the upper limit:
      https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
      You might check into a -3dbm or -6dbm coax line attenuator to install.
      Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
      Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
      Be sure there are no coax cable line splitters in the between the modem and ISP service box.
      Be sure your using good quality RG6 coax cable up to the modem.
      Start with removing any amplifiers, signal attenuators, or splitters from the coax.
      From there check the line for kinks, damage, moisture in the line.
      Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
      Be sure to power OFF the modem for 1 minute then back ON.
      https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
      https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
      https://highspeed.tips/docsis-events/
      I'll see if I can get some review from NG on this as well.
      • Wavicle's avatar
        Wavicle
        Thanks- I appreciate the information.  This is a new construction house with all new coax including the run from the demarcation box outside the house to the Cox pedestal 30 feet away in the front yard. Terminations look good but I cannot inspect the run the guys came by and trenched in the yard a week ago (but there was no change in reliability from that work). I made sure there is only 1 coax connected at the demarc and it runs straight to the modem with no splitters, no amplifiers or even connectors. And that run from the demarc to the modem is about 20 feet in the crawl space (looks fine).
        I agree on power levels and I typically try to get +2 dBmV across the channels and hope for 44-ish dB SNR. This configuration is way off but still in the window for the CM3000.  I had Cox re-provision the modem this morning and so far it's holding the Internet but has lost the upstream OFDM lock as the modem status shows.
        With Cox when you bring your own modem they simply look the other way and say you're on your own for tech support. Therefore they will not assist in analyzing the CM3000 error log even though it points to them for problems. They only care about getting a signal on the cable at the modem-- beyond that, they don't care and won't lift a finger to help. I do have some testers (Klein) to ring out the coax runs but I do not have a high frequency signal source or a scope to get a look at the frequency response.
        I've read about far too many issues with the CM3000 on Cox and that is why I plan to decommission it when the Arris arrives.
  • Event Log:
    TimePriorityDescription
    Wed Aug 12 13:20:39 2026(Warning (5))TCS Partial Service;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Wed Aug 12 12:33:52 2026(Error (4))DBC-ACK not received;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Wed Aug 12 12:33:49 2026(Warning (5))TCS Partial Service;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Wed Aug 12 12:32:50 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Wed Aug 12 12:32:10 2026(Notice (6))US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 9 13.;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Wed Aug 12 12:31:10 2026(Warning (5))Dynamic Range Window violation
    Wed Aug 12 12:31:10 2026(Warning (5))RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Wed Aug 12 12:31:03 2026(Notice (6))DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Wed Aug 12 12:30:58 2026(Notice (6))TLV-11 - unrecognized OID;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Time Not Established(Warning (5))DHCP WARNING - Non-critical field invalid in response ;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Time Not Established(Notice (6))Honoring MDD; IP provisioning mode = IPv4
    Time Not Established(Critical (3))SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
    Wed Aug 12 12:29:46 2026(Critical (3))Resetting the cable modem due to docsDevResetNow
    Wed Aug 12 12:28:06 2026(Critical (3))Resetting the cable modem due to docsDevResetNow
    Wed Aug 12 11:59:09 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Wed Aug 12 10:30:51 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Tue Aug 11 17:35:05 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Tue Aug 11 15:01:22 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Sun Aug 09 21:24:04 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Sat Aug 08 19:54:40 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Sat Aug 08 06:40:18 2026(Critical (3))No Ranging Response received - T3 time-out;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Sat Aug 08 06:40:13 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Fri Aug 07 10:05:00 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Fri Aug 07 08:39:19 2026(Critical (3))No Ranging Response received - T3 time-out;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Fri Aug 07 08:39:17 2026(Critical (3))No Ranging Response received - T3 time-out;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Thu Aug 06 12:59:10 2026(Critical (3))Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Thu Aug 06 12:55:38 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
    Thu Jul 23 06:40:36 2026(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:94:01:ab:79:50;CMTS-MAC=f8:a7:3a:f0:e5:d5;CM-QOS=1.1;CM-VER=3.1;
  • Status:
    Cable Diagnostic
    Status:   Poor
    Action:
    [Partial Service]
    If the Partial Service mode does not go away within a few hours (Click the Refresh button after each step):
    1) Make sure the coaxial cable is tightly connected.
    2) Remove any unnecessary splitters.
    3) Replace any required ones.
    4) Contact your service provider for troubleshooting help.
    CM Status:
    Downstream Status:
    Upstream Status:
     Refresh Save Cable Diagnostic Info
    Advanced Information
    Frequency Start Value
    This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
    Starting Frequency
    Startup Procedure
    ProcedureStatusComment
    Acquire Downstream Channel747000000 HzLocked
    Connectivity StateOKOperational
    Boot StateOKOperational
    SecurityEnabledBPI+
    IP Provisioning ModeHonor MDDIPv4 only
    Downstream Bonded Channels
    ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
    1LockedQAM2565747000000 Hz6.6 dBmV42.8 dB00
    2LockedQAM2561723000000 Hz5.7 dBmV42.6 dB00
    3LockedQAM2562729000000 Hz5.6 dBmV42.5 dB00
    4LockedQAM2563735000000 Hz5.9 dBmV42.6 dB00
    5LockedQAM2564741000000 Hz6.2 dBmV42.7 dB00
    6LockedQAM2566753000000 Hz7.0 dBmV42.8 dB00
    7LockedQAM2567759000000 Hz7.1 dBmV42.9 dB00
    8LockedQAM2568765000000 Hz7.2 dBmV42.9 dB00
    9LockedQAM25625117000000 Hz0.9 dBmV39.8 dB00
    10LockedQAM25626123000000 Hz1.2 dBmV40.1 dB20
    11LockedQAM25627129000000 Hz1.3 dBmV40.4 dB10
    12LockedQAM25628135000000 Hz1.2 dBmV40.6 dB30
    13LockedQAM25629141000000 Hz1.0 dBmV40.7 dB30
    14LockedQAM25630147000000 Hz0.9 dBmV40.7 dB00
    15LockedQAM25631153000000 Hz1.4 dBmV40.8 dB00
    16LockedQAM25632159000000 Hz1.7 dBmV41.1 dB00
    17LockedQAM25633165000000 Hz1.8 dBmV41.1 dB00
    18LockedQAM25634171000000 Hz1.8 dBmV41.1 dB00
    19LockedQAM25635177000000 Hz1.7 dBmV41.1 dB00
    20LockedQAM25636183000000 Hz1.9 dBmV41.1 dB00
    21LockedQAM25637189000000 Hz2.1 dBmV41.3 dB00
    22LockedQAM25638195000000 Hz2.3 dBmV41.4 dB00
    23LockedQAM25639201000000 Hz2.6 dBmV41.4 dB00
    24LockedQAM25640207000000 Hz2.8 dBmV41.5 dB00
    25LockedQAM25641213000000 Hz2.9 dBmV41.6 dB00
    26LockedQAM25642219000000 Hz2.9 dBmV41.6 dB00
    27LockedQAM25643225000000 Hz2.9 dBmV41.6 dB00
    28LockedQAM25644231000000 Hz2.8 dBmV41.6 dB00
    29LockedQAM25645237000000 Hz2.6 dBmV41.6 dB00
    30LockedQAM25646243000000 Hz2.4 dBmV41.5 dB00
    31LockedQAM25647249000000 Hz2.3 dBmV41.4 dB00
    32LockedQAM25648255000000 Hz2.3 dBmV41.4 dB00
    Upstream Bonded Channels (Partial Service)
    ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
    1LockedATDMA25120 Ksym/sec24000000 Hz43.5 dBmV
    2LockedATDMA15120 Ksym/sec17600000 Hz43.5 dBmV
    3LockedATDMA35120 Ksym/sec30400000 Hz43.0 dBmV
    4LockedATDMA45120 Ksym/sec36800000 Hz43.5 dBmV
    5Not LockedUnknown0000.0 dBmV
    6Not LockedUnknown0000.0 dBmV
    7Not LockedUnknown0000.0 dBmV
    8Not LockedUnknown0000.0 dBmV
    Downstream OFDM Channels
    ChannelLock StatusProfile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier
    Number Range
    Unerrored
    Codewords
    Correctable
    Codewords
    Uncorrectable
    Codewords
    1Locked0 ,1 ,2 ,3159300000000 Hz2.78 dBmV42.0 dB296 ~ 78954654767104168805080
    2Not Locked000 Hz0 dBmV0 dB0 ~ 4095000
    Upstream OFDMA Channels
    ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
    1Not Locked9 ,13636800000 Hz36.5 dBmV
    Extended Upstream Transmit Power
    Current System Time:Wed Aug 12 14:34:37 2026
    System Up Time:02:04:22
  • After 5 weeks of absolutely frustrating up and down Internet, I'm done with the CM3000 on Cox. It is not compatible and resetting it 10 times a day is crazy. Cox will NOT downgrade the FW and I made that request at the highest level with a tech that knew it can not be done. So NG says your ISP controls firmware and the ISP says you need to get firmware from the modem manufacturer. In other words, Cox upgraded my CM3000 to V6.01.04 upon 1st provisioning and crippled it... until perhaps they get around to fixing problems and pushing out a new update to eliminate the critical time sync, dynamic range window warning, TCS partial service warning, and many more problems. There have also been dozens of attempts to download new firmware and they all fail for being incompatible or corrupt and that puts the modem into an unstable state. Cox says they are not pushing FW updates... so then who is? Not likely NG, which Cox suggested it was. That was a waste of $280 to test this out but note that Cox still has the CM3000 on their list of certified DOCSIS 3.1 modems.
    I'll try another brand that Cox claims does not have user reports like the CM3000 (switching to the S34).
    • FURRYe38's avatar
      What FW version is on the Cm3000 currently?
      Please post a copy and paste of the modems connection status and event log page.
      https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
      https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
      What is the brand and model of the host wifi router connected to the modem?
  • I have already sent Netgear the diagnostics they requested, as a result of being able to connect to the modem at 192.168.100.1
  • I have performed the modem reset, and connected the modem LAN port directly to a computer via an ethernet cable. The DHCP server at Cox gives me an IP address, but I cannot connect to the internet.
    • FURRYe38's avatar
      You'll need to keep in contact with NG support then.
      • Timaes's avatar
        Timaes
        Yes. And in the case of both Cox and Netgear I wish I could speak with someone, live, and in real time in order to get this squared away. :(
  • Yes, the modem worked just fine from 08/18/2025 to 11/16/2025. And I have run through the reboot/reset process several times with the Cox representative on the phone with me. I also have an outstanding case with Netgear, and they just keep telling me to do the same thing.
    As an aside, I'm retired after 40+ years working in the IT industry, so I'm pretty familiar with how this works.
    • FURRYe38's avatar
      Power OFF and back ON differs from reboot and reset.
      You will need to put the CM3000 series back online and get it associated with the ISP. Have one ethernet connected PC connected to the modem. Not a router and see if you can get internet access.
      Then capture the CM3000s cable connection and event logs from the modem and post here.
      So far your the only one posting about this version of FW since NG released it.
  • Sometime around 11/18/2025 Cox Communications upgraded my CM3000 to the v6.01.04 firmware. It has been unusable ever since. When connected up to a router, the internet connection is never completed. I've tried both an MR80 mesh router and an older R7000P. Luckily, I still have my CM1200 modem, which works just fine with either router.
    This CM3000 is still under warranty, since I purchased it in August of this year (2025). Netgear support seems to be giving me the runaround: having me reboot, reset, reset, etc. They've never admitted to an issue with this modem.
    Any suggestions as to how I can better get their attention and resolve this?
    • FURRYe38's avatar
      Had the CM3000 been fully associated with the ISP and then after that after connecting a router to the CM3000 modem, power OFF The modem for 30 seconds then back ON, then give about 1 minute power ON the external wifi router?
