AlColl's avatar
AlColl
RCN C6300 Not Pairing
I just moved from Xfinity to RCN in Chicago and am using the same Modem/Router. I reset factory settings, gave RCN my MAC Address, and after a few hours I am still not getting it to lock in on the internet light.
Looking at the diagnostics, it says it has only locked 1 US channel and 1 DS channel.
What am I doing wrong? Is it the modem/router? Is it RCN?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    I would check with your ISP they may need to send a tech out to check your lines.
    DarrenM
    • AlColl's avatar
      AlColl
      The lines have worked with two different modem/routers. Still not sure why my Netgear won't link up... maybe I have the wrong MAC ID? I don't have the original box or manual so I had to go into the system specs to find it... maybe it's not the right one though.
      Is there a way I can find my Netgear MAC address with certainty? The one my ISP wants?
      • DarrenM's avatar
        DarrenM
        Did you ever register it with netgear support if so you could access it in your netgear account.
        DarrenM
