Trenzer
Apr 01, 2012Follower
XAVB5601 problems
1. Why is there no support page for the XAV5601 (or the 2-kit, XAVB5601)??
2. Just installed this kit. Speeds are good, connection is made around 350 Mbps according to the Powerline utility. BUT, the connection drops every now and then. When I'm surfing the web, Google Chrome sometimes says 'Sending request..' and after a while I get to see a DNS error. My modem/router (192.168.0,1) isn't reachable as well. This takes a minute and then the connection seems to work again. This is unworkable .. any hints?
Tried reproducing this, thought it especially happened when they just 'woke up' but it also happens when they've been operating for a while.
I didn't have this problem with a network cable / wireless.
- BemorphAspirantHi,
Still seeing issues, I have now reported this issue to Netgear.
My reference number is 21685411.
I recommend all of you to also report your issues it's easy! Also refer them here and also to my reference number. There is power in numbers!
http://support.netgear.com/general/contact/default.aspx Just choose email and be prepared to enter the serial number on the backside of the unit.
Best regards,
Bemorph - BemorphAspirant
begad wrote: After 3 nights of drop out free usage the drop outs are back with a vengeance...
Just quoting you so you'll find your way back here :)
I just received my first response and they want the following information:
1. How does the middle LED on the power line shine when the connection drops?
2. Have you always had this issue with it, or is it something that's started recently?
3. Could you please specify exactly when the drops happens, and in correlation to what? For instance, does it happen when you stream a HD movie, or when you download something from the web?
4. What internet service provider do you have?
5. What is the speed of your internet connection?
6. What is the name and model of your router?
7. What firmware version do you have (check with powerline utility)?
Just thought I'd supply the questions here so that anyone else who opens a ticket can supply the answers right away.
//Bemorph - BemorphAspirantShort update.
My issue has been escalated to technicians, lets see what happens :)
//Bemorph - benmmellorNoviceBit of a thread revival here as I've got the same issue.
Looks like they seem to lose their 'handshake'.
when I suffer a connection drop (I have a ping -t www.google.co.uk running in the background), I see packets get dropped, my desktop switch shows the port the homeplug in my office goes off and also the homeplug goes into some sort of loop where it reboots. All the LED's on the homeplugs go off at this point.
After a short moment, network traffic resumes.
This is getting very frustrating! - benmmellorNoviceJust borrowed a set of TP-Link homeplugs from my brother in law. Tested in the same sockets over the same 'infrastructure' and not one dropped packet!
It's definitely the plugs that are the issue! My house is only 10yrs old and the wiring was checked by my 'sparky' when having additional sockets fitted to some rooms. No issues found.
Maybe they just need to change the code to remove the 'sleep' mode! - begadNoviceI have been offered a pair of XAVB5501's in exchange for my "faulty XAVB5601" because apparently there are no 601's in stock.
Not sure what to do as I found this thread http://forum1.netgear.com/showthread.php?t=69792&highlight=xavb5501 and the problems sounds awful familiar...
One thing I did do was swap my plugs around and so far no drop outs... - begadNoviceRight so swapping the plugs didnt work but it did help indentify which plug was faulty so I have returned the faulty plug for a XAVB5501...hopefully it will work :)
- begadNoviceI sent of my faulty XAVB5601 and recieved a 5501 two days later (quick turn around) and so far so good :)
- benmmellorNoviceWell looks like you got better support than me.
I'm still waiting for a replacement - it was received on the 22nd August by the UK RMA centre. They told me that had no replacement stock and no idea when they would have them. I sent the one homeplug which seemed to be erratic in it's behaviour - maybe I should have sent both and demanded they both be swapped out.
As it stands I have one XAV5601 stuck on my desk.
Quite frankly I've found the NetGear Support and RMA team shockingly bad in handling this PMR and RMA.
You get bounced around the call centres, and being blunt, each time I end up in an 'Asian' call centre even if I do manage to speak to one who I can a) understand and b) have enough volume to hear them, the call gets cut-off (at their end conveniently) when they start to run out of on-screen excuses!
I guess I better block out another hour of my day tomorrow to be given yet more excuses about my RMA then point them at this thread and demand a replacement product for BOTH my powerline adapters! - benmmellorNovice
begad wrote: I sent of my faulty XAVB5601 and recieved a 5501 two days later (quick turn around) and so far so good :)
Lucky you - I sent mine in on the 22nd August and still not had a replacement. Just excuses and dropped calls from the Asian helpdesk techs.
