Fixitplease
Nov 12, 2016Aspirant
WNDA3100V3 BSOD Security Check Error with disconnect and reconnects
Every time my Netgear WNDA3100V3 USB WIFI adapter disconnects and then reconnects to the internet, my computer shuts down and displays the BSOD (blue screen of death) that says the stop code. "Kerne...
Fixitplease
Nov 15, 2016Aspirant
If I disconnect it from the computer and don't plug it back in, my computer is fine. But if I plug it back in in connects the internet, then I get the BSOD. Also, if I lose the wifi signal and it reconnects by itself I get the BSOD.
JamesGL
Nov 17, 2016NETGEAR Employee Retired
Hi Fixitplease,
If you have another computer, try installing the adapter and check if the same issue. Try cleaning as well the registry of your computer(Check microsoft).
JamesGL
Community Team
- FixitpleaseNov 18, 2016Aspirant
I have uninstalled using Revo Uninstaller to completely remove it from my system and tried to install and uninstall and use 3 of the drivers on the Netgear website. Nothing seems to work and I have since installed a Tp-link Pci wifi card and I have had zero problems since. I believe the Netgear device is not compatible with Windows 10 Pro/My Computer.
- JamesGLNov 23, 2016NETGEAR Employee Retired
Hi Fixitplease,
Please check your inbox.
JamesGL
Community Team
- bluezeonJan 12, 2017Aspirant
We are receiving Bluescreen with this Adapter quite often too. 3-4 times a day... Details below
tcpip.sys 15f665
Windows 10 64 bit
Netgear WNDA3100V3 N600
ntoskrnl.exe
