debauchery's avatar
May 31, 2016
cannot close ports 21 and 443 on r7000 router
my nighthawk r7000 router is running firmware v1.0.6.28_1.1.83 and i am comcerned with the security of my network since ports 21 (ftp) and 443 (https) are both always opened for exploits. these results i am referring to are online scan from gibson research's shield up utility.
i have closed port forwarding within the router management to no avail. and this is only the first 1056 ports scanned.
  • AWESOME! that did it!
    just down graded to firmware v1.0.5.64_1.188
    rebooted unit and wah-lah...port 21 (FTP) is closed to shields up port scanner.
    Thanks!
  • Go to ADVANCED > USB Functions > ReadySHARE Storage and disable FTP and HTTPS (via Internet).
    • rlee33156's avatar
      rlee33156
      port 21 is still open after applying changes you recommended.
      rlee33156
      port 21 is still open, after applying changes instructed.
    • debauchery's avatar
      debauchery
      Tutor
      port 21 is still open even after disabling ftp and https in readyshare usb functions.
      • TheEther's avatar
        TheEther
        Guru
        Do you have UPnP enabled?  If so, disable it.  Reboot the router.
    • TheEther's avatar
      TheEther
      Guru
      I have not seen any one else with your problem.  Can you try a different port scanner to cross check the results from gibson's research?
      Last thing to try is a factory reset.
  • I don't think grc gibson research's shields up is the problem. I am running netgear's firmware. Maybe i should try firmwares from shibby.
    No disrespect intended here.
    • TheEther's avatar
      TheEther
      Guru
      I just noticed that you are are running v1.0.6.28_1.1.83.  It's been recalled due to bugs.  You should downgrade to 1.0.5.64.  Get it here.  It's strongly recommended for you to perform a factory reset after installation and reconfigure by hand.  Do not restore from a backup file because it could be incompatible.
      There are several, great 3rd party firmware options for the R7000.  I use Asuswrt-Merlin.
        debauchery
        Tutor
        Thanks!
