Roadturn's avatar
Feb 13, 2016
Nighthawk R7000 and Centurylink Actiontec C1000A
This router worked great with my cable modem service. After switching to Centurylink DSL, though, it's not performing well at all.
Running straight from the Actiontec C1000A output to the internet input on the R7000, then out from the router via cable to my notebook, I get about one-fourth the bandwidth available when running straight from the Actiontec to the notebook. My aim is to provide better wireless for the house. Wireless performance, of course, is the same as the cabled experience... worse than not using the Netgear at all.
  • The WAN settings page and the one page that shows DSL Transport mode, VLAN etc.
    • Roadturn's avatar
      Roadturn
      Tutor
      Well... I bridged it again and went through the process... now it's working. Got me.
      One more thing. Netgear is broadcasting both a 2.4G and 5G signal... do I need to run both? Does it affect performance? If one, which to choose and how to get rid of the other?
      • avtella's avatar
        avtella
        Prodigy
        Having both 2.4Ghz and 5Ghz is actually better, that way you don't saturate one band or the other alone on the router. Have faster devices that support ac use the 5Ghz band and slower devices use the 2.4 Ghz band so that slow devices don't slow down the faster ones.
        Glad you got transparent bridging working, enjoy! :smileyhappy:
  • Correct, so we can se how the default connection is, before proceeding.
  • In the R7000 Internet settings do as follows:
    Change does Internet require login to yes.
    Change Internet Service Provider to PPPoE
    Enter CenturyLink provided login/password
    Leave Service Name empty
    Set Connection Mode to always on
    • Roadturn's avatar
      Roadturn
      Tutor
      Internet Connection Status shows Not Connected (and won't connect)
  • It could be a double NAT/Firewall issue due to active firewall in both devices or wrong user MTU setting in the R7000, should be 1492 max for DSL, you can try the following:
    1. Bridge mode: the modem only acts as a modem and all routing and PPPOE dailing are done by the R7000, I have CenturyLink and this is what I do, works well.
    2. DMZ: Setup a DMZ, to put your R7000 outside your modems own firewall in your CenturLink modem for the R7000, be sure to set the MTU to 1492 in the R7000 as well.
    3. AP Mode for router, where all router does is provide wireless and modem does all routing/NAT functions, however I would avoid this as the R7000 is far more powerful than the C1000A which overheats easily under load.
    • Roadturn's avatar
      Roadturn
      Tutor
      Avtella, I know enough to sort of understand what you're saying. Let me see if I the Actiontec will set to bridge mode first. I don't think it will, but I'll try.
      • Roadturn's avatar
        Roadturn
        Tutor
        Well, I was able to switch the Actiontec to transparent bridge mode. Now I have no internet at all via Centurylink... whoops.
