mjeeda
Apr 03, 2018Aspirant
Power LED is blinking R7800
Hi, today i update my router R7800 from app on iphone
after that my router is Power LED Is Blinking and no wifi
i was on version 10.0.2.36
Thank you.
No it should be something like this: tftp -i 192.168.1.1 PUT nameoffirmware.img
If you wanna make things simple just rename the file to like a.img so its easier to type or paste in the command prompt.
- TorkilHAspirant
Got the same problem. :-(
Try a Factory reset on the router and setup from scratch...
- avtellaProdigyYou may need to do a tftp flash with the latest firmware or older one if you want. I posted detailed instructions on how but the forum decided it needs to be moderated for some reason.
Just follow these instructions:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-softbricked/td-p/414034- mjeedaAspirant
Theres this FAQ:
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
Hopefully a factory reset is all thats needed.
