Router2371's avatar
Router2371
Cannot Turn off Smart Connect!
Honestly, about ready to just be done with this RS500 router.  Today, it decided to turn on Smart Connect all by itself....we suddenly could not find our network SSIDs.  Logged in, found that Smart Connect was suddenly on, so all under one SSID.  Which we do NOT want.  To make matters worse, we cannot uncheck it!  I have messed with it for the past 2 hours trying everything  and it will not let me uncheck the box.  Anyone ever have this happen before, and how do I fix it?  Am I stuck with having to do a full factory reset and have to redo ALL of my settings all over again?  This has been the worst router I have ever had.
If anyone can help, please do because I am completely stuck.
Tried the app, tried incognito windows, tried 3 different browsers, cleared page caches, you name it.  I cannot uncheck the box.  1.2.7.2, no updates available.  This is just crazy with this thing.
  • Is there anyone from NG that could weigh in here?  Like, what has happened....how did this just turn itself on in the middle of the day, and now we cannot uncheck the setting?
    • FURRYe38's avatar
      Which browsers did you try? MS Edge, Firefox or Opera?
      Can you access it by using the Nighthawk mobile app?
      Can you select manual channels 1 and 40 or 11 and 48?
      Can you disable the wifi radios all together?
      How about powering OFF the router for 30 seconds then back ON?
      Brand and model# ISP modem/ONT that the RS router is connected too?
      • Router2371's avatar
        Router2371
        Not sure what Opera is, but Edge, Firefox, Chrome, also private windows for each of those.
        Noted earlier, the app does not have any controls for smart connect
        Channels I can select but since SC is on, I cannot separate out the SSIDs, pw, or choose what bands I want devices to connect to.
        I did turn off the radios, back on...hid the ssids, and even installed last version of FW.  no change. so I updated back to current fw.
        I have turned the router off and on so many times now I cannot even remember lol.  every time, it comes back locked on SC, cannot turn it off.
        Modem is my Moto MB8600, has always been fine.  like i said, this just happened out of nowhere midday yesterday.  we were in living room, suddenly lost wifi.  noone could find their ssids.  logged in, saw SC was now on, and we cannot turn it off.  It just did it all on its own while we were just playing a board game.
  • BH_C's avatar
    BH_C
    NETGEAR Expert
    I just sent a PM to Router2371 to see if we can get the router's config file. Thanks.
  • I have posted this before...doing so again, as I am looking for further help.  Each day, normally around 3pm. my devices lose connection and freeze up.  Sometimes my digital photo frames and ALWAYS my Amazon Echo Show 5.  I have done factory resets on the devices.  I have unplugged the units and the RS500 router a hundred times.  I even just did a factory reset on the RS500, but that was because it turned on Smart Connect by itself and grayed out the option to turn it off.  Even with all that, each day, my items freeze around the same time.  The only thing I can think of is the DHCP leases ending every 24 hours.  Is there any way to exclude a device from doing so?  I have already set a reserved IP address using the mac address of my echo show 5.  Has not helped.  I did an experiment and connected it to my phone as a hotspot around 250pm....it did NOT freeze up at 3 as it normally does.  So it seems to be the router.
    Does anyone have any ideas, solutions....does anyone else have this issue?  I am on the latest firmware.  I did also re-flash to last FW...same problem.  So went back to the current FW.  I have tried everything I know to do....turned off and on protection engine, QoS, etc.  I really thought that by reserving the IP address, it would fix it for the echo show 5, but nope.  Thanks.
    • FURRYe38's avatar
      What was the results of the PM with NG? Did they send you any information or a build of beta FW?
        Router2371
        No.  They just told me to do a hard reset.  Which did get it so I could uncheck the Smart Connect.  However, when I re-loaded the saved configuration, it went back to forced on, unable to be turned off.  So there is SOMETHING in a setting that is forcing that on.  They do not know what what or why.  Told me to just do another hard reset.  And still no answer on why my devices freeze up every 24 hours.  Not helpful at all.  Which is why I am posting here again.  They have no idea why it is doing that, or forcing on Smart Connect all on its own.
      • WarmHelp_NTGR's avatar
        WarmHelp_NTGR
        NETGEAR Expert
        Hi Router2371,
        I have sent you a private message. Please kindly check it when you have a moment.
  • Thanks for the explanation, but that still leaves me....where?  Once again today at 301pm, my devices froze.  If not DHCP, then what else can I change?  Should I just turn off DHCP completely?  I have already turned off IPv6 too, just as a precaution.  Did not help.  It does not happen when on my phone hotspot.  It can be on an ad or it can be on a photo.  Could my router be just refusing to renew the dhcp to my devices at those earlier times you mentioned?  I have given a static IP address to the Echo.  Has not helped.  I just do not know what to do.
  • Hi Router2371,
  • In the end, NG could not help me, had no idea.  Looked at logs, etc....agreed it just turned on by itself and did not know why it would not allow anyone to turn it off.  Basically useless.  I stopped talking to them, and just did a factory reset.  Sucked, as I had to re-do all the settings.  I tried to load a saved config file but when I did so, SC was back on.  So, there was something, some setting, that was forcing that to be on.  Did another factory reset and started over.
