btaroli
May 25, 2016Prodigy
Can't activate ReadyCLOUD on my 516 running 6.5
Decided I might try ReadyCLOUD after hearing all the news of change around 6.5. But when I sign in with my MyNetgear login on the NAS, it spins for a bit and simply responds with:
"Unable to join the device to ReadyCLOUD. Your device may be misconfigured. Please email [email protected]"
I did the needful but response has been... lacking. Has anyone else run into this and know what may be the issue? Willing to work through it, but that requires actual responsiveness from the Netgear end.
Did some searching this evening and found https://community.netgear.com/t5/ReadyCLOUD/NAS-not-on-LAN-in-ReadyCloud/td-p/949253
Bingo! So, why is it that nowhere in the FAQ or activation step does it mention or warn that UPnP has to be enabled on the NAS itself? It would also be helpful if I didn't have to stumble into the ReadyCLOUD settings on the NAS myself to learn that you have to also set the flag to signify which port to use for incoming connections, for those of us who don't run UPnP on their firewall.
So far so good. :)
- btaroliProdigyYes it has a static IP. It's been resolving DNS properly for years and has devices I have mapped to it through my firewall. Only the insane enable UPNP on Internet facing devices; so no it is not enabled on my firewall.
- btaroliProdigy
So far so good. :)
- mdgm-ntgrNETGEAR Employee Retired
If you have a static I.P. set on the NAS have you specified the DNS Server addresses correctly?
is UPNP enabled on your router?
