Yurik1
Sep 04, 2016Tutor
Cloud can not discover device
Having my RN10400 for about a year now and had no problems to use it as a storage for home network. Now I truying to set up cloud permissions for users, but following steps described in manual I get ...
- Sep 05, 2016
Yurik1,
You should be able to connect your ReadyNAS to ReadyCLOUD now.
Sep 04, 2016Guru - Experienced User
What firmware are you running?
Are you using a static IP address for the NAS? If so, make sure you configured at least one DNS server
- Yurik1Sep 04, 2016Tutor
Hi Stephen,
I running latest firmware - 6.5.1
Not sure about IP as I am not so technical. I guess it is not static as the last number always changes after I reboot the system. http://192.168.1. ....
- StephenBSep 04, 2016Guru - Experienced User
You definitely are getting the address automatically then (your router is assigning it).
There is some information here you might review: http://kb.netgear.com/app/answers/detail/a_id/29785/~/readycloud-faq
Spend 2 days reading FAQ
Was hoping to get help here
But it so NETGEAR!
