Yurik1
Sep 04, 2016Tutor
Cloud can not discover device
Having my RN10400 for about a year now and had no problems to use it as a storage for home network. Now I truying to set up cloud permissions for users, but following steps described in manual I get ...
- Sep 05, 2016
Yurik1,
You should be able to connect your ReadyNAS to ReadyCLOUD now.
Sep 04, 2016Guru - Experienced User
What firmware are you running?
Are you using a static IP address for the NAS? If so, make sure you configured at least one DNS server
Yurik1
Sep 04, 2016Tutor
Hi Stephen,
I running latest firmware - 6.5.1
Not sure about IP as I am not so technical. I guess it is not static as the last number always changes after I reboot the system. http://192.168.1. ....
- StephenBSep 04, 2016Guru - Experienced User
You definitely are getting the address automatically then (your router is assigning it).
There is some information here you might review: http://kb.netgear.com/app/answers/detail/a_id/29785/~/readycloud-faq
- Yurik1Sep 04, 2016Tutor
Spend 2 days reading FAQ
Was hoping to get help here
But it so NETGEAR!
You specificially talked about the manual, but not the FAQ. We aren't mind readers, we can only use the info you provide.
I don't work for Netgear, and since I'm not using the new ReadyCloud I can't (and don't) offer a lot of advice on it. It is a holiday weekend in the US, hopefully you will get useful help soon.
One thing you could try is adding google's DNS server to your NAS configuration (8.8.8.8 and/or 8.8.4.4).
