Yurik1
Sep 04, 2016Tutor
Cloud can not discover device
Having my RN10400 for about a year now and had no problems to use it as a storage for home network. Now I truying to set up cloud permissions for users, but following steps described in manual I get ...
- Sep 05, 2016
Yurik1,
You should be able to connect your ReadyNAS to ReadyCLOUD now.
Yurik1
Sep 04, 2016Tutor
Hi Stephen,
I running latest firmware - 6.5.1
Not sure about IP as I am not so technical. I guess it is not static as the last number always changes after I reboot the system. http://192.168.1. ....
Sep 04, 2016Guru - Experienced User
You definitely are getting the address automatically then (your router is assigning it).
There is some information here you might review: http://kb.netgear.com/app/answers/detail/a_id/29785/~/readycloud-faq
- Yurik1Sep 04, 2016Tutor
Spend 2 days reading FAQ
Was hoping to get help here
But it so NETGEAR!
- StephenBSep 04, 2016Guru - Experienced User
You specificially talked about the manual, but not the FAQ. We aren't mind readers, we can only use the info you provide.
I don't work for Netgear, and since I'm not using the new ReadyCloud I can't (and don't) offer a lot of advice on it. It is a holiday weekend in the US, hopefully you will get useful help soon.
One thing you could try is adding google's DNS server to your NAS configuration (8.8.8.8 and/or 8.8.4.4).
Enjoy your weekend Stephen,
And thanks for your time truying to help. You do your best.
Truyed to add google DNS - nothing changed. Cloud services Offline.
I just never in my life wasted so much time on something there always solutions available but not with RN. So dissapointed by its complecity.
- SERGIO_SERRASep 04, 2016Aspirant
I've the same problem!
- mdgm-ntgrSep 05, 2016NETGEAR Employee Retired
SERGIO_SERRA your system should now be fixed. It's showing the correct serial number and MAC addresses now.
