Yurik1
Sep 04, 2016Tutor
Cloud can not discover device
Having my RN10400 for about a year now and had no problems to use it as a storage for home network. Now I truying to set up cloud permissions for users, but following steps described in manual I get ...
- Sep 05, 2016
Yurik1,
You should be able to connect your ReadyNAS to ReadyCLOUD now.
Sep 04, 2016Guru - Experienced User
Yurik1 wrote:
Just sent logs to [email protected]
Then you sent them to the wrong place. Read the instructions here: http://kb.netgear.com/app/answers/detail/a_id/21543/~/how-do-i-send-all-logs-to-a-readynas-forum-moderator
Include "Attn: mdgm" in the subject line, and put a link to this thread in the body of the email.
Yurik1
Sep 04, 2016Tutor
Just done it
- mdgm-ntgrSep 04, 2016NETGEAR Employee Retired
Yurik1, the DNS addresses for Google are 8.8.8.8 and 8.8.4.4
You put in 8.8.8.4 as the secondary DNS.
Also I see you have some proxy settings for ReadyCLOUD configured incorrectly. Do you have a proxy on your network? You put in some proxy settings and specified the I.P. address of your router as the port which is clearly wrong.
SERGIO_SERRA your issue is very different. On your NAS a MAC address is showing as the serial number.
- mdgm-ntgrSep 05, 2016NETGEAR Employee Retired
Yurik1,
You should be able to connect your ReadyNAS to ReadyCLOUD now. - Yurik1Sep 05, 2016Tutor
Uuuhuuu,
Cloud cervices available. Geat!
Thank you so much!
