robrub
Feb 21, 2015Tutor
ReadyCloud connect problem after Netgear takes control
Hi I had several problems with 6.2.2. and 6.2.3 betas and on 2 occasions the Netgear helpline took control of my RN312. After both distant controls, I lost my connection to ReadyCloud. I had to ca...
rovingmedic
Feb 22, 2015Tutor
I experienced similar behaviour during my tech support interventions. My NAS was setup using static IP. When I put it in tech support mode it booted with a DCHP IP. This is different from the static IP. This broke the ReadyCLOUD link. I also had all kinds of issues trying to re-establish the link correctly after a factory reset. What I learned is that you need to make sure that your NAS IP is set up exactly how you want it before creating the ReadyCLOUD connection (in my case using a static IP) and that this IP is reconfigured again after any interventions to reconnect to the existing ReadyCLOUD admin account.
BTW, I always used the same NAS name (different from the default name that includes part of the MAC address). My NAS name was never changed after tech support interventions unless I reset the NAS to factory default (delete all data and reset all settings).
