mixsetup
Nov 26, 2017Aspirant
readycloud does not connect but raidar does
Hi there Well readycloud does not connect but raidar does and I can go through the folders with raidar. It logs in and then just says conneccting and thats where it sits trying to connect. I have ...
Retired_Member
Nov 27, 2017Hello mixsetup
If you want to access NAS on ReadyCLOUD client in LAN network,please make sure upnp service is enabled.
if you wan to access NAS share in Wan network,please make sure Leaf network interface of your Windows has obtained IP address from ReadyCLOUD server correctly,you can check its status at Network and Sharing Center>Change Adapter Setting>Leaf Networks Adapter>Details,the correct IP should be 5.*.*.*.
Btw,have you installed firewall application on Windows?
mixsetup
Nov 27, 2017Aspirant
Thanks I it has ip address strating with 5
Did notice it says No internet access for the Leaf Network adapter.
I have AVG free,Malwarebytes Pro on my system.
It was working perfectly then the next day just had stopped.
- StephenBNov 27, 2017Guru - Experienced User
Look on the cloud page of the NAS web ui, and see what status it shows for internet access and the readycloud service.
- mixsetupNov 28, 2017Aspirant
Because it doesn't even show up on the cloud page and says offline usingthe readycloud software on the computer should I just reset back to factory defaults? Do you think that would work at all?
- StephenBDec 03, 2017Guru - Experienced User
Well, I think you should go to the NAS admin web ui directly, and look at the readycloud and internet status on the cloud page (https://nas-ip-address/admin )
